Page 3 of 3 FirstFirst 123
Results 31 to 34 of 34
  1. #31
    Jan 2012
    EU
    Quote Originally Posted by ptikkala View Post
    Anyone have hires pictures of this particular ecu... received one water damaged ecu and cannot read cpu atm... power ic is gone so need to replace that and fix those traces. One very small cap is also loose.
    here you have picture... water damages are bad, better to replace used ecu.
  2. #32
    Yes. Trying to revive this so that i can dump the cpu. Customer wants his tuned maps to the new ecu. Thanks
  3. #33
    Jun 2011
    Chieti,Italy
    same problem, the ecu is locked after egr off. I found other ecu different software and hardware. I tried to clone writing entire backup in the other ecu the engine works then goes off and safe on display. search solution, thanks
    readed whit fgtech v54 writted whit mpps v18
  4. #34
    Feb 2012
    Default edc17c46 cloning
    hello i need help can someone do edc17c46 clone i know with abitus is easy
