Results 1 to 15 of 16
    Nov 2008
    wite hart lane
    Default help needed here.
    hi guys, been awhile since i messed about with the wii... but my neighbour dropped over with a black wii. 4.3E and i used letterbomb to mod it... now it installed homebrew channl. but as i was about to install bootmii as ios , i seen it was in purple writing and said Bootmii cant be installed as a ios ..... usb loader wont even load either.... any help please.. i will post a system check later..
    Nov 2008
    wite hart lane
    here is my system check .. please help thanks guys,,
    sysCheck v2.1.0b19 by Double_A and R2-D2199 Nano
    ...runs on IOS58 (rev 6176).
    Region: PAL
    System Menu 4.3E (v514)
    Priiloader installed
    Drive date: 2009.11.21
    Homebrew Channel 1.1.2 running on IOS58
    HomebrewFilter ist nicht installiert
    Hollywood v0x21
    Console ID: 156179372
    Boot2 v4
    Found 73 titles.
    Found 44 IOS on this console. 13 of them are stub.
    IOS3 (rev 65280): Stub
    IOS4 (rev 65280): Stub
    IOS9 (rev 1034): No Patches
    IOS10 (rev 768): Stub
    IOS11 (rev 256): Stub
    IOS12 (rev 526): No Patches
    IOS13 (rev 1032): No Patches
    IOS14 (rev 1032): No Patches
    IOS15 (rev 1032): No Patches
    IOS16 (rev 512): Stub
    IOS17 (rev 1032): No Patches
    IOS20 (rev 256): Stub
    IOS21 (rev 1039): No Patches
    IOS22 (rev 1294): No Patches
    IOS28 (rev 1807): No Patches
    IOS30 (rev 2816): Stub
    IOS31 (rev 3608): No Patches
    IOS33 (rev 3608): No Patches
    IOS34 (rev 3608): No Patches
    IOS35 (rev 3608): No Patches
    IOS36 (rev 3608 Info: rev 3351): Trucha Bug ES Identify NAND Access
    IOS37 (rev 5663): No Patches
    IOS38 (rev 4124): No Patches
    IOS40 (rev 3072): Stub
    IOS41 (rev 3607): No Patches
    IOS43 (rev 3607): No Patches
    IOS45 (rev 3607): No Patches
    IOS46 (rev 3607): No Patches
    IOS48 (rev 4124): No Patches
    IOS50 (rev 5120): Stub
    IOS51 (rev 4864): Stub
    IOS52 (rev 5888): Stub
    IOS53 (rev 5663): No Patches
    IOS55 (rev 5663): No Patches
    IOS56 (rev 5662): No Patches
    IOS57 (rev 5919): No Patches
    IOS58 (rev 6176): USB 2.0
    IOS60 (rev 6400): Stub
    IOS61 (rev 5662): No Patches
    IOS70 (rev 6912): Stub
    IOS80 (rev 6944): No Patches
    IOS236[36] (rev 65535 Info: rev 3351): Trucha Bug ES Identify NAND Access
    IOS249 (rev 3608): Trucha Bug ES Identify NAND Access
    IOS254 (rev 65281): BootMii
    BC v6
    MIOS v10
    Report generated on 2014/12/19.
    DK Veteran Keithuk's Avatar
    Aug 2010
    England
    As far as I know Bootmii will only install in IOS on a 2009.11.21 Wii, it installs in IOS on my 2008.
    As you may have read on here that's a typical sysCheck of a Wii that's only been softmodded as you have 13 IOS's that are Stub. You do have IOS36 and IOS236 that's all but you need to reduce that 16 down to 4 or 5.
    Download ModMii6.3.1 and run ModMii.exe from Windows. Use the SU option from the main menu and find the location of the sysCheck.csv from the sysCheck which is on the root of the SD card. That will download all missing wads and apps to COPY_TO_SD sub folder just add all files and folders to the SD card.
    ModMii only installed 2 d2x v8.0 wads download d2x v8 Final wad pack and put these in the wad folder on the SD card, install all 7 wads when you install the other wads.
    Put the SD card back in the Wii and run Homebrew. You already have IOS236 but it won't hurt to install it again. Run IOS236 Installer v5 Mod first before you install any other wads. Multi Mod Manager (MMM) should be the first app listed select it and load it. Once running scroll down to WAD Manager and press 'A' that will default to all wads in the wad folder. If you want to install all wads shown just press 1 that will list all wads you want to install press 'A' again to install them all.
    Watch for the Installed OK message after each one. If any don't say that message make a note of the wad name and back out. Scroll down to the wad that didn't install and press the + button the put a green + next to it then press 'A' to see that wads name listed then press 'A' to install again.
    If you have to update to 4.3 then the Shopping Channel may not work. If it doesn't without doing another system update don't bother just install my RVL-Shopping-21
    Do another sysCheck to make sure everything installed correctly and post that.
    Then you just have a to find a compatible mains powered USB hard drive to add your games onto and download USB Loader GX 3.0 to run them.
    Keith
    2010 Golf GTD (170)
  4. The Following User Says Thank You to Keithuk For This Useful Post:
    pudzy (20th December, 2014)
    Nov 2008
    wite hart lane
    hi keith, im reading this but dont understand it , can you spoonfeed me ere.... ( find the location of the sysCheck.csv from the sysCheck which is on the root of the SD card. That will download all missing wads and apps to COPY_TO_SD sub folder just add all files and folders to the SD card.)
    thanks m8
    Nov 2008
    wite hart lane
    ok , did as said above everything seems to loaded ok... think i may have made mistake with partition HDD any way this is systemcheck have a look m8
    Region: PAL
    Hollywood v0x21
    Boot2 v4
    Found 85 titles.
    Found 55 IOS on this console. 5 of them are stub.
    IOS11 (rev 16174): Trucha Bug NAND Access
    IOS20 (rev 16174): Trucha Bug NAND Access
    IOS30 (rev 16174): Trucha Bug NAND Access
    IOS36 (rev 3608): No Patches
    IOS40 (rev 16174): Trucha Bug NAND Access
    IOS50 (rev 16174): Trucha Bug NAND Access
    IOS52 (rev 16174): Trucha Bug NAND Access
    IOS60 (rev 16174): Trucha Bug NAND Access
    IOS62 (rev 6430): No Patches
    IOS70 (rev 16174): Trucha Bug NAND Access
    IOS80 (rev 16174): Trucha Bug NAND Access
    IOS202[60] (rev 65535 Info: hermesrodries-v6): Trucha Bug NAND Access USB 2.0
    IOS222[38] (rev 4 Info: hermes-v4): Trucha Bug ES Identify NAND Access USB 2.0
    IOS223[38+37] (rev 4 Info: hermes-v4): Trucha Bug ES Identify NAND Access USB 2.0
    IOS224[57] (rev 65535 Info: hermesrodries-v6): Trucha Bug NAND Access USB 2.0
    IOS245[37] (rev 21008 Info: d2x-v8final): Trucha Bug NAND Access USB 2.0
    IOS246[38] (rev 21008 Info: d2x-v8final): Trucha Bug ES Identify NAND Access
    IOS247[53] (rev 21008 Info: d2x-v8final): Trucha Bug NAND Access USB 2.0
    IOS248[55] (rev 21008 Info: d2x-v8final): Trucha Bug NAND Access USB 2.0
    IOS249[56] (rev 21008 Info: d2x-v8final): Trucha Bug NAND Access USB 2.0
    IOS250[57] (rev 21008 Info: d2x-v8final): Trucha Bug NAND Access USB 2.0
    IOS251[58] (rev 21008 Info: d2x-v8final): Trucha Bug NAND Access USB 2.0
    BC v6
    MIOS v10
    Report generated on 2014/12/20.
    Aug 2010
    England
    Well that new sysCheck looks ok, if you want to remove IOS16 Stub then install my cIOS16-v257 but that will make no difference for running games of an HDD.
    Have you tried to run any games of a mains powered hard drive?
    Keith
    2010 Golf GTD (170)
    Nov 2008
    wite hart lane
    yes i used my kids hdd,, works good.. so i re partitioned the portable with eraseus.. working ok now thanks keith merry xmas
    Nov 2008
    wite hart lane
    back again... helping out a friend here with his wii.. not playing games, as custom ios 249 in a stub. anyway i did a system check maybe ye can have a look
    Region: PAL
    Drive date: 2007.02.13
    Hollywood v0x11
    Console ID: 72858397
    Boot2 v4
    Found 105 titles.
    Found 48 IOS on this console. 8 of them are stub.
    IOS222 (rev 65280): Stub
    IOS223 (rev 65280): Stub
    IOS249 (rev 65280): Stub
    IOS250 (rev 65280): Stub
    BC v6
    MIOS v10
    Report generated on 2015/01/03.
  10. #9
    Aug 2010
    England
    Just repeat everything I said in post #3. You already have IOS236 but it won't hurt to install it again.
    Keith
    2010 Golf GTD (170)
  11. #10
    Nov 2008
    wite hart lane
    chers m8.. works a treat... but why every now and again, i get the error custom 249 is a stub please reinstall?????????
  12. #11
    Aug 2010
    England
    If you do everything I said then there shouldn't be a problem the bit you missed was.
    Quote Originally Posted by Keithuk View Post
    Along with cIOS222[38]-v4.wad, cIOS223[37-38]-v4.wad
    Keith
    2010 Golf GTD (170)
  13. The Following User Says Thank You to Keithuk For This Useful Post:
    pudzy (4th January, 2015)
  14. #12
    Nov 2008
    wite hart lane
    guys,,, me again. kids broke hdd... so i got new one copied 240 games from m8 hdd,, but for some reason the covers wont download... my kids are yound and go by pictures to play games.. now they have now covers so its a pain..... any ideas, i have try to d/load covers via menu on wii, and wii game manager.. any help
  15. #13
    Aug 2010
    England
    Game covers are stored on the SD card.
    USB Loader GX - SD:\config\images\(3D), config\images\2D, config\images\disc, config\images\full
    CFG USB Loader - SD:\usb-loader/covers/2D, usb-loader/covers/2D, usb-loader/covers/3D, usb-loader/covers/disc, usb-loader/covers/full
    Wii Flow - SD:\wiiflow\boxcovers (full cover), SD:\Wiiflow\covers (2D)
    If your Wii has a web connection you can download covers in options or search for the game name or better the game ID number at http://www.wiiboxart.com/pal.php then add them to the correct folders on the SD card. Each download will have the same filename for full, 2D, 3D, disc, e.g. R5UP41.png, SKCE20.png which is the game ID number so don't mix them up.
    Keith
    2010 Golf GTD (170)
  16. #14
    Nov 2008
    wite hart lane
    on the covers problem on d/loading , im getting error writing sd:/usb -loader/covers/3d/R5FP41.ping error HTTP/1.1 404 NOT FOUND
  17. #15
    Aug 2010
    England
    As I've said your Wii needs an internet connection to download game pictures. You can also search for the game ID number from http://www.wiiboxart.com/pal.php
    Your example http://www.wiiboxart.com/wiigame.php?game=R5FP41 The full one doesn't show right so that's corrupted.
    Just click on each picture then right-click on the picture and save it to correct folder on the SD card. All pictures have the same filename so don't mix them up.
    USB Loader GX:
    2D = SD:\config\images\2d
    3D = SD:\config\images\3d
    Disc = SD:\config\images\disc
    Full = SD:\config\images\full
    CFG USB Loader:
    2D = SD:\usb-loader\covers\2d
    3D = SD:\usb-loader\covers\3d
    Disc = SD:\usb-loader\covers\disc
    Full = SD:\usb-loader\covers\full
    WiiFlow:
    2D = SD:\wiiflow\covers
    Full = SD:\wiiflow\boxcovers
    Keith
    2010 Golf GTD (170)
