Hi, can anyone please remove me CP or make it vergin?
Audi MMI 2G
eeprom 24C64
MMI_24C64_with_CS.rar
regards
Audi MMI 2G
eeprom 24C64
regards
figani (29th March, 2019), ProTekAuto (11th November, 2023)
erase to "00" 1D8-1E1 for virgine ... after CS pin is 0000 .. and you must teach CS ..
AIHAM (18th February, 2021), ampibali (24th January, 2023), Col19 (25th October, 2020), dziongas (15th January, 2018), gobe (13th March, 2023), gogoli (18th March, 2018), hbalazs (26th November, 2019), kaalis (4th March, 2019), kaziukas1958 (16th December, 2020), multiaudi (20th July, 2017), pipina (24th December, 2014), sannyk (12th May, 2021), TERNOCOD (25th December, 2014), tomxx (1st March, 2020), yahia1908 (17th February, 2020)
I allready solved it but thank you for help
regards
eddysson (11th January, 2022)
Hello, please, tell me. You can remove CP from MMI 2G HIGH module permanently? I need to remove CP from mu MMI unit. Can You help me?
How did you solve the CS with the bin file extracted from 24c64a? Please help me with this file. Q7 CP MMI 2G. Why do you have password on the fixed file? What's the different between making virgin and remove component protection?
Thanks,
Louis
Hello Pipina,
I got an A8 HU 4E0035729A to replace my old 4E0035729 and I got the CP as expected, please remove the CP from the 24c64a of the new one please.
Thanks,
Louis
dognmonkey (16th April, 2020)
Hi, i need remove cp from audi mmi 2g
4e0035729
inside 24c64
tanks for help.
Thanks Pipina, will report back
Hello Pipina,
The sound works as by default, the CP no longer there, but the suspension menu disappeared, I had to turn on the Green Menu to enable everything back, BUT the Telephone BT no longer exist, I did check in the CAN GATEWAY, it's enabled but the MMI doesn't see the or load the Telephone Menu. If I programmed the OLD 24c64a to the new one, everything works and also the CP is removed also. Can you fix the last image for the BT to work?
Thanks,
Louis
is there any way to remove component security from this mmi 2 without the car ? i have AVDI , but is asking me to connect it to the car and at the moment car is not here. thanks . i attasch 24c64.
Wichj is the procedure with VAS / ODIS ?
Dosen't matter how hard is to repair something as long is made by humans and thinked by humans !
