Page 5 of 46 FirstFirst 1234567891015 ... LastLast
Results 61 to 75 of 678
  1. #61
    @pipina,
    can you please do CP off for this unit??
  2. #62
    Hello Pipina, i have problem CS is damaged. I need you if you can disable it ... please
    It is Audi A4
  3. #63
    RS-BG
    Hello All,
    Is it possible some Help ...
    I wish to make test table for audi MMI - 2g unit :
    I bay from one crash car : Gateway , Control Head Interface 4E0035729, Display, Console.
    From second crash car I bay Amplifier, Tuner modul , Navigation modul , CD changer modul ....
    I make assemble for all unit on table and working , normal but not have sound because … becouse all unit not from same car and now sure have active CP.
    Please if i m right:
    Modul - Tuner and modul Navigation from mmi2g dont have CP ... is it corect ?
    Modul - CD charger, Control Head Interface, Amplifier have .CP and mast disable or pair with gateway ?
    General ... what me need to pair all this modul on table to have sound ?
    And is it possible to disable CP from Amplifier ?
    Thanks in advance
  4. #64
    Aug 2011
    Hi, try should work. Report!
  5. The Following 2 Users Say Thank You to pipina For This Useful Post:
    ezmou (10th June, 2021), fruti (3rd August, 2018)
  6. #65
    RS-BG
    Hello All ,
    Is it possible to disable CP on Amplifier "
    4F0035223 -09
    SW:4F0910223B-027
    Sound Amplifier Basic
    AS4 - 0001
    Or make this dump in virgin state ?
    Thanks in advance
  7. #66
    Jul 2018
    @pipina,
    can you please do CP off for this unit's??
    thank'S
  8. #67
    RS-BG
    Default Audi - MMI 2G - component security
    Helo,
    Try and write the result ... !
    Zeca
  9. The Following User Says Thank You to zecab For This Useful Post:
  10. #68
    Aug 2011
    For amplifier 99% times enough to copy CP area in EEPROM now I work on CP off for amplifier. Will let know when finding the solution.
  11. #69
    Dec 2016
    Hello, is there any comfortable way, how to read this eeprom of MMI 2G without soldering or special clamps?
    Basically... I have 2 MMIs, one as a spare coming from crashed car that I no longer have. Then, I have mine full working, except the thing that there is FBAS missing, so instead of soldering so many components, i would like to exchange my main MMI 2G HIGH for that one, that I have as a spare, but with FBAS (i have rear view camera preparation and hybrid tv-tuner prepared for installation). Is there any way how to put it in my car and make it working? I have VAS, AVDI2018, KESS and VCDS available, but no idea how to make it...
    Can anybody be so kind and help me? I am solving this for 5th day and Im starting to get really crazy...
  12. #70
    Feb 2015
    Italy
    anyone has infoes about vw mib1 and mib2 cp? can it be done by e2p? someone knows if is possible to activate functions without dealer code?
    yhank you
  13. #71
    Oct 2013
    Swap eeproms and it will work fine. I did same for mine.
  14. #72
    hello members
    please disable the cp from the dump.
    thanks, alex
  15. #73
    GB
    Hello Pipina. Can you help me with CS off MMI2G 4E0035729 . Thank you
  16. #74
    GB
    Solved. Thanks anyway
  17. #75
    robert1232's Avatar
    Dec 2010
    Ireland ;)
    Default 4f0035769b CP
    hi i need help
    clear CP PLEES
    gays help my
