Page 16 of 36 FirstFirst ... 6111213141516171819202126 ... LastLast
Results 226 to 240 of 529
  1. #226
    Feb 2020
    Default please CP off
    Hi !
    Is it possible remove component protection ?
  2. #227
    Aug 2011
    Hi, should work OK.
    Regards
  3. The Following User Says Thank You to pipina For This Useful Post:
    Enrico81 (25th February, 2020)
  4. #228
    Feb 2020
    Thank you ...
  5. #229
    Jan 2010
    Quote Originally Posted by kaw View Post
    Hi! Can you help me please with cp off ?
    4e0 035 729
    sw: 4e0 910 735 p
    Regards
    Maybe someone can help me please
  6. #230
    Oct 2012
    need help pls.
    mmi2 component protection remove
  7. #231
    Jan 2009
    Hi need help cp off radio unit from a4 b8 4g1035053 h
  8. #232
    Latvia
    Hi, please help me to disable CP in Audi A6 4F Control Head MMI 2G.
    Bought a car with no sound and found that someone has changed head unit.
  9. #233
    Aug 2011
    Quote Originally Posted by Istais View Post
    Hi, should work.
    Regards
  10. The Following User Says Thank You to pipina For This Useful Post:
    Istais (24th March, 2020)
  11. #234
    Sep 2019
    Default MMI Componet Security
    hi Pipina is it possible to turn off CP for my mmi audi a6 c6
  12. #235
    Oct 2014
    romania
    i have seen that if you turn off cp you lose coding and you never can do coding with cp off dump...
  13. #236
    Oct 2014
    romania
    so after pipina helped me the radio worked ,thank you ,but i have to put original dump and adapt online with vas..for coding to work
  14. #237
    Aug 2011
    Quote Originally Posted by Chemail View Post
    Hi, should work OK.
    Regards
  15. The Following User Says Thank You to pipina For This Useful Post:
    Chemail (5th April, 2020)
  16. #238
    Aug 2011
    Quote Originally Posted by BoNzOtM View Post
    Hi, strange never have problem with coding after cp off. Did you check with VCDS instalation list?
    Regards
  17. #239
    Apr 2020
    CA, USA
    How did you solve the CS with the bin file extracted from 24c64a? Please help me with this file. Q7 CP MMI 2G. Why do you have password on the fixed file? What's the different between making virgin and remove component protection?
    Thanks,
    Louis
  18. #240
    Apr 2020
    CA, USA
    Hello Pipina,
    I got an A8 HU 4E0035729A to replace my old 4E0035729 and I got the CP as expected, please remove the CP from the 24c64a of the new one please.
    Thanks,
    Louis
