one bit change
Hi guys I have a problem with the fap off this ford focus. The classic switch off the edc16c34 E5 does not work, the dpf off implementing Volta Sensor Decoding seems to work, but in addition to clear the entire area dtc me a message appears on the dashboard "Diesel filter clogged". Does anyone have a tested solution for this car. It is a ford focus 1.6 tdci Euro 5. With the classic switch off I find errors related to the probes of differential pressure, because of the dpf emptied.
one bit change
i think In the dump find "01 01 00 0C 3B 0D" string and replace it to "00 01 00 0C 3B 0D
i have problem with this car. The single bit solution doesn't work and regeneration started. The solution with volta work but erase the dtc table. Everyone have a tested solution. I need help also remapping. Thank you in advance
i d say more than 1 bit. but as always sensors must be ok just for bits solutions ;D
Good FAP OFF solution is with all sensors off and not 1 bit solution.
BR
All full worked manual solutions - FAP/DPF OFF, Adblue/SCR OFF, EGR OFF, TVA OFF, SWIRL OFF, O2/Lambda OFF, DTC OFF and etc
Our database available for download 24/7 on EVC server for all legal WinOLS users
your dump off
alejandrobr1995 (6th August, 2018)
Not good solution.
i think you dont know what are you writing,that solution is not good it is just perfect solution,done many cars and never ever problems,just checksum with BDM,first check after than tell good or bad,you didint check just write it is not workning,first check before you will write not true thinks,i done file and i wait for report,we will see working or not working...i am sure it will be 100% ok because i never ever had any problems,i done for free don't want any money$$$,no password FREE FOR EVRYBODY !!!
OK ... and you know what you doing ? Maybe you also tried to disconnect EGT and differential sensors, Additive and etc ? I am sure that not. When you tried and all is ok, then post solutions and named is as "good" ?r "worked".
BR
you check my map?any anserw?
