elmontydecai (16th November, 2019)
I have tested solution//
CHIPTUNING dpfoff EGROFF immooff edc17,med17 EEPDOM CRC EDC17, MED17,
I can do it work on 100%
DPF/FAP off, AdBlue off, EGR off, Throttle valve off, Flaps off, DTCs off, Lambda off,
hi what I found on another forum, EDC17 is the same as how to remove egr EDC16 maybe this can help. Best Regards
Cleared 6 hysteresis cards 00,000, EGR off and the problem is solved. can be confirmed to me
not worry I would find the egr off solution!!!
And Did you find maps?
hi I expect that you help me
you must find a right way to turn off egr search better in you file.
And I told you earlier that I have 100% worked decision for your egr but is not free
BR
