Results 1 to 15 of 15
    Feb 2014
    Default Renault Clio 3 Autoliv 610796000 8201043701 help?
    Hello
    Can someone help me with clean dump for this airbag module?
    Renault Clio 3 Autoliv 610796000 8201043701 95640 dump:
    95640.rar
    Thank you!
    tukey izmir
    Default hello
    Quote Originally Posted by autoTkey View Post
    Hello
    95640.rar
    Thank you!
    hello pass pm
  3. The Following 2 Users Say Thank You to muratasutay For This Useful Post:
    alama28 (23rd November, 2019), autoTkey (29th December, 2014)
    Feb 2014
    Thanks, I'll test it after the holidays and let you know if it works.
    Feb 2014
    It's working fine, thank you!
  6. The Following User Says Thank You to autoTkey For This Useful Post:
    auto80 (7th January, 2015)
    Feb 2014
    I'm having a problem with another airbag of the same type(at least the numbers are the same - Autoliv 610796000 8201043701) from the same car model. I already tried with EcuVonix tool and also with Airbag Service tool but it doesn't work with neither of them.
    The strange thing is when you look at the HEX - it is organized differently from other dumps of the same SRS module. Most dumps I found for this module(like the one in the first post) have some car data in the beginning, including VIN and below is the crash data. On this dump it appears that the memory is written in 4 identical sections and there's no VIN. I mean the same data is written 4 times in the eeprom - from 0 to 7FF, then again from 800 to FFF, and third time from 1000 to 17FF and fourth time from 1800 to the end of the memory 1FFF. And the tools I mentioned can't seem to understand this. They clean the memory as it is one whole but not a 4 identical sections memory. Does anyone know what I'm talking about and knows a way to clean this?
  8. #6
    Mar 2011
    Hello
    Can someone help me with clean dump clio 3
  9. #7
    Jan 2014
    Default airbag
    try and report,
    pass in pm.
  10. #8
    Mar 2011
    it`s not working
  11. #9
    Jan 2014
    Default airbag
    try this............
  12. #10
    May 2016
    Moldova
    good afternoon. how to find out the password to open the file. thanks in advance
  13. #11
    May 2016
    Moldova
    i need for renault modus 2010 year. thank you
  14. #12
    Feb 2014
    AirBag Service Tool will clean this crash for you. Find it with google.
    My problem was that UPA doesn't read those EEPROM's(95640) so better use Xprog or something else.
  15. The Following User Says Thank You to autoTkey For This Useful Post:
    dvdpgn (21st July, 2020)
  16. #13
    Sep 2016
    Germany
    may I have the dump either? Would appreciate for a short reply.
    Many thx in advance...
  17. #14
    Aug 2014
    Hi there!
    I need help to clear crash data and error if it`s possible
    Renault Clio III Autoliv 610796000 8201043701
    Thanks anticipated!
  18. #15
    Nov 2016
    Default cleared pass on pm
    cleared pass on pm
  19. The Following User Says Thank You to mizou40 For This Useful Post:
    catastefan (15th February, 2020)
