Anybody know if 03g906013k EDC17u01 from 2009 BLS engine has TPROT?
could I read/write it by OBD without bootmode?
H.W
H.W
if your ecu data are this the car have TP and you can do this with boot
which car is this?
ibiza 1.9 tdi 105 hp?
hw vag : 03G906013K
sw vag : 2940
hw bosch : 0281014883
sw bosch : 1037395434
H.Wessel (27th December, 2014)
Yes, this is the car and the ecu, so if it has TPROT I have to make it by boot,
thanks for your help friend
I make various seat Ibiza engine bls in obd (edc17u01), with cmdtec without problem.
hw vag : 03G906013K
sw vag : 2940
All with virtual read form cmdserver.
Br.
If you can read this car in obd, write in obd not problem, tprot is low, TPROT_V00.10.00
Br.
H.Wessel (28th December, 2014)
many persons here dont have original tools and i can not know which tools are using, i give always the safest way for work
Ok then, I will try to read by OBD with my galletto, thanks for your advise, I think that with TPROT in all cases you can read by OBD but you read rubbish, and the you write rubbish and destroy the ecu.
I have galletto v52 euro clone, and another tool-toys like mpps but I usually use galletto, thanks for your advice, if I see some dificult to read, I will take it out and do by boot
Galleto 2 can not read this ecu by OBD, so I will have to take out and read by boot this week.
