Results 1 to 10 of 10
    H.Wessel's Avatar
    Jul 2010
    Default edc17u01 BLS engine TPROT?
    Anybody know if 03g906013k EDC17u01 from 2009 BLS engine has TPROT?
    could I read/write it by OBD without bootmode?
    H.W
    carmageddon's Avatar
    Apr 2010
    Italy
    if your ecu data are this the car have TP and you can do this with boot
    which car is this?
    ibiza 1.9 tdi 105 hp?
    hw vag : 03G906013K
    sw vag : 2940
    hw bosch : 0281014883
    sw bosch : 1037395434
  3. The Following User Says Thank You to carmageddon For This Useful Post:
    H.Wessel (27th December, 2014)
    H.Wessel's Avatar
    Jul 2010
    Quote Originally Posted by carmageddon View Post
    which car is this?
    hw vag : 03G906013K
    sw vag : 2940
    Yes, this is the car and the ecu, so if it has TPROT I have to make it by boot,
    thanks for your help friend
    Sep 2014
  6. #5
    Aug 2009
    I make various seat Ibiza engine bls in obd (edc17u01), with cmdtec without problem.
    hw vag : 03G906013K
    sw vag : 2940
    All with virtual read form cmdserver.
    Br.
  7. #6
    Aug 2009
    If you can read this car in obd, write in obd not problem, tprot is low, TPROT_V00.10.00
    Br.
  8. The Following User Says Thank You to gezame For This Useful Post:
    H.Wessel (28th December, 2014)
  9. #7
    Apr 2010
    Italy
    many persons here dont have original tools and i can not know which tools are using, i give always the safest way for work
  10. The Following 2 Users Say Thank You to carmageddon For This Useful Post:
    gezame (28th December, 2014), H.Wessel (28th December, 2014)
  11. #8
    Aug 2009
    Yes, friend, you are rigth.
    I only he shared experiences.
  12. The Following User Says Thank You to gezame For This Useful Post:
  13. #9
    H.Wessel's Avatar
    Jul 2010
    Quote Originally Posted by gezame View Post
    Br.
    Ok then, I will try to read by OBD with my galletto, thanks for your advise, I think that with TPROT in all cases you can read by OBD but you read rubbish, and the you write rubbish and destroy the ecu.
    I have galletto v52 euro clone, and another tool-toys like mpps but I usually use galletto, thanks for your advice, if I see some dificult to read, I will take it out and do by boot
  14. #10
    H.Wessel's Avatar
    Jul 2010
    Galleto 2 can not read this ecu by OBD, so I will have to take out and read by boot this week.
