Results 1 to 10 of 10
    Default Lagun II 2006 0281012770 DPF and EGR problem
    Can somebody please, help with these ecu in order to totally remove EGR and DPF?
    FGTech read it as EDC16C39 SW1037379278 but I am confused because on NET I found same number as EDC16C3.
    Original dump in attachement!
    flashorig.rar
    Thanks!
  2. The Following User Says Thank You to tihiuvek For This Useful Post:
    br.balazs (11th October, 2016)
  3. #2
    must be edc16c3 , renault doesnt have any edc16c39
  4. The Following User Says Thank You to ominimicu For This Useful Post:
    tihiuvek (29th December, 2014)
  5. #3
    Do you know how to remove DPF and EGR I forget to say it is 1.9 DCI.
  6. #4
  7. The Following User Says Thank You to ominimicu For This Useful Post:
  8. #5
    Thanks my friend!
    I program your file and no any problem regarding DPF or EGR (egr is closed and connector disconected).
    Unfortunately I got plenty of the smoke (black smoke at 3000 RPM not at idle) is it possible that smoke map has been affected too?
  9. #6
    HAs DPF been removed? sensors disconected? If yes and still get smoke. Put ori back on, do a DPf reset with diag tool and flash back my mod!
  10. #7
    Hi all!
    Can somobody do egr off 1.9 dci?
  11. #8
    Dumps with org file
  12. #9
    Jul 2011
    egr off..
    EGR Actuator plug have be disconnected..
    pass.pm
  13. #10
    Jul 2011
    pass-pm......
  14. The Following 2 Users Say Thank You to draganelektricar For This Useful Post:
    bodzio012 (20th February, 2016), ganm55 (12th June, 2023)
