Results 1 to 15 of 16
    Default ALPINE IVE-W530BT PASSWORD
    Someone with these hole radio can understand where to find password?
  2. The Following User Says Thank You to giruzzo For This Useful Post:
    alle bmw (20th September, 2022)
  3. #2
    Dec 2010
    Russia
    Read IC605
    Calc codes from serial FORD V-series from FORD dealer login
    ok I try think it's a eeprom 24c02?
    thank.
    Mobilart thank I read eeprom you indicated
    anyone can help me with this radio?
    thank.
    cubica1's Avatar
    Feb 2012
    Serbia
    somewhere exists byte which switch code 0n/0ff 01 to 00 ....perhaps did somebody knows whichone ? tssop8 24c02 a little bit difficulty to resold many times...
    or somebody knows code position
    thanks in advance,
    cuby
    edit: solved
    Jun 2018
    Did you guys figure out the security code? cause i'm stuck with a useless headunit after car change..
    Feb 2019
    Default security code on this eerom 24c02 is there some way we can read it
  10. The Following User Says Thank You to meganet555 For This Useful Post:
    traxpalicaru (15th May, 2019)
  11. #9
    smoggy's Avatar
    Apr 2009
    UK North East
    try code 526305
  12. The Following 4 Users Say Thank You to smoggy For This Useful Post:
    LABDANI AHMED (15th May, 2019), masterskay62 (16th May, 2019), nigrou (15th May, 2019), petronijul (16th May, 2019)
  13. #10
    Feb 2019
    code didnt work wrong code
  14. #11
    Feb 2019
    any help ?
  15. #12
    Oct 2013
    Ukraine
    Quote Originally Posted by meganet555 View Post
    any help ?
    Hi.
    try..............937239
  16. The Following User Says Thank You to masterskay62 For This Useful Post:
    LABDANI AHMED (22nd May, 2019)
  17. #13
    shooting's Avatar
    WALES
    any help ?
    Try 6xxxxx … EDIT: Ignore, non of the above codes are correct
    wbr
    Don't confuse "Standing on my Shoulders" with "Treading on my Toes" ..
  18. #14
    Feb 2019
    on the screen there is numbers from 0 to 9 how to put XXXXX
  19. #15
    Jan 2019
    Algeria
    Enter the numbers in a normal way by pressing the desired number, for example the first number 9 Press 9 and so on.
