Page 26 of 45 FirstFirst ... 16212223242526272829303136 ... LastLast
Results 376 to 390 of 661
  1. #376
    Thanks! But why does it come MMS when I choose your profiles and not MMSH ?
    What are the inputs in the 400 profile?
    Access:
    Encapsulation:
    Width:
    Height:
    FPS:
    Sample rate:
    Deinterlace:
    VIDEO
    Codec:
    Bitrate:
    Scale:
    AUDIO
    Codec:
    Bitrate:
    Channel:
  2. #377
    Also tried your HTML code. But no video is shown on my homepage. I use your 400 profile!
    Cant I see it myself on my homepage since im the one whos streaming it?
  3. #378
    Nov 2008
    Quote Originally Posted by djrobbie View Post
    yes you can see in your site,there is something wrong in streaming or in the code you have in the site
    the streaming should be with mms protocol and not http to receive in in your site
    mms same as mmsh but if you mms://xxx.dynd.org:123 in vlc will not play but if you add mmsh is will play do not bother yourself by this is amattar of words
    regarding the 400 profile it i will post them tomorrow
    regards
  4. #379
    Problem is that my router doesnt support loopback function. So I cant se my own stream by entering WAN.
    DynDNS.com - Support -- Knowledge Base -- Loopback Connections
    But if I use Firefox, then MMS wont show up with my friends test. Only if there is MMSH in the HTML code.
    Look forward for your reply on the specs for the 400 profile.
    I hope you can make a couple of more profiles in the software, there are many that has fiber and VDSL like me.
  5. #380
    You didnt answer today as you promised.
  6. #381
    Nov 2008
    sorry but i had problem with the net
    This is the source code of the program and demonstate everthing
    If mobile = 0 Then
    If adslprofile = "low" Then
    vcodec = "WMV2"
    vbitrate = "256"
    vscale = "0.25"
    acodec = "mp3"
    abitrate = "16"
    ascale = "1.0"
    ElseIf adslprofile = "medium" Then
    vcodec = "WMV2"
    vbitrate = "512"
    vscale = "0.5"
    acodec = "mp3"
    abitrate = "16"
    ascale = "1.0"
    ElseIf adslprofile = "high" Then
    vcodec = "WMV2"
    vbitrate = "1024"
    vscale = "0.5"
    acodec = "mp3"
    abitrate = "32"
    ascale = "1.0"
    End If
    regards
  7. #382
    Thanks for reply!
    I have installed TINY WINDOWS XP on my computer, since your software is better and designed for that OS.
    But, after installing the 6.0F version (and i have tried to reinstall, reboot computer) it simply wont start? I click the application but nothing happens. It installed every addons as earlier, but the program wont start.
    Any Ideas ?
    UPDATE:
    Also tried the 6.0 BETA 2 version, same problem, wont start!
  8. #383
    Nov 2008
    Thanks for reply!
    Any Ideas ?
    UPDATE:
    did you install vlc and better in its default deirectory c:\videolan\vlc
  9. #384
    Yes, have installed vlc (newest version) in C:\Program Files\VideoLAN\VLC
    Should this be reinstalled on c:\videolan\vlc ?
  10. #385
    Nov 2008
    sorry i mean C:\Program Files\VideoLAN\VLC
    i am uploading portable version of the program now, i will give you link after few minutes
    when try to open the program do not forget to remove it from task mananger ir processes first if present there
  11. #386
    Nov 2008
    This portable version,please unpack and run exe
    please test it and inform me about result
    Tunisiasat dreambox player&streamer6F-portable
  12. #387
    I have finally found out how to use Dreambox VLC Streamer v1.2 - By HellX at www.digsat.net
    The reason it didnt work earlier on my stream was simply that I chose a video scale on 1.0. If i choose a videoscale on 0,5 (width="192" height="290") or lower, everything runs smoothly with bitrates from 500kbps to 8000kbps.
    I think I will be using Dreambox VLC Streamer v1.2 since it till now has been more stable, less cpu power, running 100% on windows XP and Windows 7. Though Tunisiasat Dreambox Player&Streamer has good potential and has som more functions, but still it is "buggy" and needs better programming for Windows 7. It also shows the video in VLC when the stream is started, which is not showed in Dreambox VLC Streamer v1.2. I believe thats just a setting when opening/calling VLC.exe
    I will use Tunisiasat Software if it comes with a function that limits the number of clients watching the stream. Is that possible?
    Portable Tunisiasat Dreambox Player&Streamer Results:
    It worked perfectly!
    Also this code runs perfectly on my homepage, showing an embeded Mediaplayer that shows my stream directly:
    </head>
    <body>
    <span> </span> <span> </span> <object classid="clsid:6bf52a52-394a-11d3-b153-00c04f79faa6" width="368" height="294" codebase="http://activex.microsoft.com/activex/controls/mplayer/en/nsmp2inf.cab#Version=5,1,52,701"><param name="name" value="MediaPlayer" /><param name="url" value="mms://YOURIP/DNS:1234" /><embed type="application/x-mplayer2" width="192" height="290" src="mms://XXXX:1234" name="MediaPlayer"></embed></object>
    </body>
    </html>
    Questions:
    Is it a way to add a script or something showing if the video is "online" or "offline"
    Is it a way to restrict the number of viewers ?
    Is there a way to "hide" the stream address?
  13. #388
    Nov 2008
    Dreambox VLC Streamer v1.2 is good program and could be more stable because it is not complicated and has less function than mine
    both work in same principal for streaming so i will not believe that one better than the other
    vlc streamer always pop up vlc player for viewing channes in local pc and for streaming ,my program pop up vlc player for streaming only if versions of vlc above .99
    you can hide your streaming to website from other unless you put password in your site
    regarding windows 7 my program runs perfectly if
    by right mouse click menu choose "run as adminstater"
    regards
  14. #389
    Jan 2009
    Default Web Streamer
    Hi mfaraj57,
    long time no speak, hope your well and see your still trying to help/support people through this thread.
    I have two new questions for you:
    1) Do you still have an up to date Web streamer progame where you can change channels remotely?
    The reason I ask is i'm away on business next week and I would like to use your second progam to view and change channles.
    2)Also is there way for your program or the other streaming program that can allow you to change channels on your dreambox and still keep streaming but showing the channel changing?
    Thanks in advance.
    Kev,
  15. #390
    Nov 2008
    Quote Originally Posted by rruunneerr View Post
    Hi mfaraj57,
    Thanks in advance.
    Kev,
    Hi Kev,thanks
    you can use the other program
    tunisia-sat dreambox web receiver 5.0.2 and you can control server program and dreambox remotely,you need only to supply in settings dns address,server streaming port
    you can change channel,stop streaming ,start streaming and even start recording in server pc
    regards
