Page 28 of 45 FirstFirst ... 18232425262728293031323338 ... LastLast
Results 406 to 420 of 661
  1. #406
    Member mikmoz's Avatar
    Nov 2008
    well a big thank you to mfaraj57 and all who have posted here i am up and running streaming with this great bit of software.took a bit of time searching through all the posts but found all the info here.it works really well and is well worth persevering till you get it right.and i am a complete novice so if i can do it anyone can.cheers
  2. #407
    Default Continous buffering problem
    Hi mfaraj57,
    Have managed to get Tunisia web receiver version 5.0.2 partly working from my office while streaming from home via web streamer/player version 6.0.0f.
    I have two problems:-
    1/ web receiver keeps on buffering very frequently. It starts buffering unti it reaches 60 % buffering then it works for a couple of seconds then it starts buffering again until it reaches 50 % and then it works for 2-3 seconds, then starts buffering again and so on> This makes watching from office nearly imposibile. Please help.
    2/ There is no voice or sound in office end.
    At home I have vlc .99 installed.
    At home A have 2 mega adsl speed ,while in office I have 1 meg adsl speed.
    3/ 1234 +5678 TCP ports are opened at home computer
    4/ 1234 +5678 TCP ports are opened at office computer.
    5/ dyndns address is updated at home.
    6/ Web receiver setting in office is:-
    A/ Server DNS address :dyndns address same as that of home computer
    B/ Server streaming port : 1234
    C/ Dreambox port : 80
    Kindly urgently help me with this great application
    Best regards
  3. #408
    Quote Originally Posted by nabat View Post
    Hi mfaraj57,
    Best regards
    I would imagine the buffering is caused by a poor upload speed.
  4. #409
    Nov 2008
    Hi Nabat
    be sure that the problem is not systemic as example from sound card or drivers or others
    test windows media player with and sound file
    if sound coming from wmp then try to install ac3filter(google)
    if this doesnot fix the problem then reinstall the program codec by installing the new version of the program present in the link in the first post in this subject 6.0.1
    if this doesnot fix the probelm the issue mostly from the image in the dream doesnot streaming sound flashing the dream with new version pli image will fix the probelm
    regards
  5. #410
    Quote Originally Posted by mfaraj57 View Post
    Hi Nabat
    regards
    Hi mfaraj57,
    Appreciate your quick response.
    1/ sound problem resolved thanks.
    2/ My biggest remaining problem is that the web receiver keeps on buffering very frequently. It starts buffering unti it reaches 60 % buffering then it works for a couple of seconds then it starts buffering again until it reaches 50 % and then it works for 2-3 seconds, then starts buffering again and so on> This makes watching from office nearly imposibile. Please help.
  6. #411
    Nov 2008
    what,s your upload speed
    you can measure it at speedtest.net
    according your upload speed choose appropriate option from settings
    if you do not mind post private message with your dns address to test(this is for your and i respect your decision if you will not send)
  7. #412
    Hi ,
    Again highly appreciate your prompt response.
    Re upload rates these are the results obtained now from "speedtest.net"
    Download Rates / Kilo bits/sec
    1739
    1750
    1771
    1700
    1710
    1520
    1815
    Upload Rates in Kilo bits/sec
    70
    152
    181
    112
    122
    91
    110
    I was using the High adsl profile
    access MMsh
    encapsulation:asf/wmv
    vcodec: WMV2
    vbitrate:1024
    v scale :0.5
    a codec: mp3
    abitrate 32
    ascale:1.0
    Please advise all settings I should use.
    Best regards
  8. #413
    Nov 2008
    according to your reading seem to have 2 mb internet speed,and low actual upload speed around 100 kb/s
    this is lowe speed and you should try low upload speed profile
  9. #414
    @ mfaraj57
    Couple of quick things.
    1st, whats a decent upload speed to achieve good results when streaming online and to JustinTV, i have both running but the results are poor.
    2nd, when setting the timer, is there was to set the channel you wish to record rather than set the timer with the channel running?
    I can record and i know ti changes to the channel when the timer starts, but couldnt see a way to just select a channel to record.
    Thanks.
  10. #415
    V.I.P. Member thered's Avatar
    Aug 2008
    hi mfaraj57 is this now working ok on a DM7025 or does it still have issues thanks
  11. #416
    Hi mfaraj57
    I have finally succeeded to get the receiver 5.02 working after I applied the low upload speed profile.
    Thank you for your help.
    The quality of the image on the receiving end is off course not the best but what shall we do -- its better than nothing.
    Its a pity that in spite of having a 2 mega speed adsl line I have
    less than 200 kilo bit/sec actual rate of upload. There is nothing I can do about it. Will try to read how to improve pc upload rate.Any ideas?
    I have two questions for you please:
    1/ What are the best "Advance" settings for Low speed upload profile I.e :
    Encpsulation
    vcodec
    vbitrate
    vscale
    acodec
    abitrate
    ascale
    2/ Which player/streamer version do you recommend to be used with receiver version 5.0.2. Is it Tunisia-sat Dreambox player and web streamer6.0.0F or Tunisia-sat Dreambox player and web streamer6.0.1 and why.
    Again my best regards and appreciation for your great acheivement
  12. #417
    Nov 2008
    Quote Originally Posted by thered View Post
    works on dm800 and dm8000 so should work on dm2025,try and tell me
  13. #418
    hi mfaraj57
    Any response to my last post please.
    TIA
  14. #419
    Nov 2008
    Hi Nabat
    web receiver program works with any version of streamer best is latest 6.0.1
    regarding the best selected advanced for low speed upload
    encapsulation
    asf/wmv
    access mms
    vbtirate 200-400
    vscale .25 or .5
    vcodec wmv2
    this same as preset low adsl low profile
    even with this low speed you can stream radio channels efficiently,you can ask your internet provider to increase upload speed
    regards
  15. #420
    Hi Nabat
    encapsulation
    asf/wmv
    access mms
    vbtirate 200-400
    vscale .25 or .5
    vcodec wmv2
    regards
    Thanks a lot and best regards
