Page 30 of 45 FirstFirst ... 20252627282930313233343540 ... LastLast
Results 436 to 450 of 661
  1. #436
    I tried this excellent software yesterday, but have some questions. I got it to work both on LAN and also from internet.
    1. I have 100/100 internet at home, how can i setup the software to get the best picture?
    2. I thought i could take this software to any computer (not on the lan at home) at work for example and start streaming, but if i have understood correct, i must start the program on a computer at home and then click on restreaming and then i can open VLC on my computer at work. This mean that you got to have access to the home computer to get this to work? Otherwise how can you start restream if you dont have the program
    3. How can you change channel from a internet based computer? Must you connect to the home computer? Or can you maybe connect to dreambox webinterface and change the channel in this gui
  2. #437
    Quote Originally Posted by kotten View Post
    Hi m8
    All answers to your questions are in this thread:
    1. Use advanced mode in program to experiment
    2. Youŗe right - just open vlc at work PC and open Network stream, where select HTTP and type xxxxxx.dyndns.org:1234 and hit play. xxxxxx should mean your registered host name on dyndns.org
    3. find somewhere in this thread the web receiver program of the same genious author and install it at your work PC. In this case you even may not press restream button on your home PC
  3. #438
    Nov 2008
    Thanks for all
    Tunisiasat web receiver program 5.0.2
    This softare installed in remote pc to control the streamer porgam and indirectly dreambox,receive stream from streamer in mms format only
    link1
    link2
  4. #439
    Quote Originally Posted by nixus View Post
    Hi m8
    1. Yes, i have seen this advanced, but my question was if someone has a good setup to use with high internet speed. Why invent the wheel once again.
    2. ok, i have to have the program started at my homepc
    3. Thanks author for the program, i will try this today at work
  5. #440
    Quote Originally Posted by mfaraj57 View Post
    Thanks for all
    link1
    link2
    I have now installed this at work, but i dont understand how it can reach my dreambox. If i press settings, the only thing i can change is DNS, port and streaming port. I can reach my dreambox webinterface from internet, i mean it is reachable on port 80
    I feel i should also send my credentials to the drambox
  6. #441
    Nov 2008
    Thank you very much mfaraj57. Have tried with several images but result is the same. I am attaching the pictures of the problem:both channels are from13E
    This is first time encountered such error
    accepted explanation that the structures of stream for some channels confilcted with display adapter drivers in mac pc
  7. #442
    Nov 2008
    we have two programs web streamer and web receiver
    web receiver software designed to work in remote pc to control streamer which in turn control dreambox
    The web receiver program interface is nearly similar to streamer except has green backgrounded colour
    The functions of receiver are stop and start streaming in streamer,start recording channels in home pc,switching channes in dreambox
    receiver also is cabable to receive stream in mms format only
    to say that receiver program will control streamer remotely and control dreambox indirectly without using webinterface,there are few minor bugs in receiver porgam and as remote controller should be wait few seconds between sending commands otherwise will not work efficiently
    receiver program connects with streamer program through port 5678,so this port should be opened and forwarded toward streamer pc ip like port 1234
    You can install receiver program in same pc with streamer and you if it works then everything will be ok and you can install in remote pce
    this picture for streamer and receiver in same pc
    this is picture taken for receiver program controlling streamer program more thousands mile far
    The program came with three preset values for choosing the best codec values better for streaming as well as advanced options for playing with different values,you can choose low or medium or high upload speed profile according to your internet speed and usually stream to mobile and stream to web tv boxes should be unchecked by default
    In general for advanced option we should follow these rules
    1-streamer streams usually in tow popular formats(access) http and mms(or mmsh both same),windows media player can receive in mms format vlc can receive both and for mms
    for http format we can use
    2- with http access we can choose and encapsulatation(ts,ps..) with any video codec and best is h264
    3- with mms access or format the better choice is asf/wmv with video codec wmv2
    regarding others like video scale better not to choose value above .5 and choose video bitrate according to your internet upload speed,you can choose video bitrate above 1000 for high internet upload speed( you have to test for that and see the quality for stream)
    for stream audio is less sensetive for the audio values and chosen audio codec you can test may value tell you get good stream sound
    for success of streaming port 1234 and assigning dns are neccessory and if these accomplished well then streaming is directforward
    you can test for port is opened or not from setting by portchekcer tool and for dns assignement
  8. #443
    Nov 2008
    to connect receiver with streamer port 5678 should be opened and forwarded to streamer pc ip(in streamer side pc ) like port 1234
    you can open receiver in same pc with streamer and to test if it is working or not
  9. #444
    Thank you my friend, but can we dare to have one day your programs reworked for mac os. This would be the best
    VLC for mac os exists and works very good
  10. #445
    Nov 2008
    To demonstrate web receiver program
    run web receiver program
    filling in settings these values
    dns address: drfaraj.dyndns.tv
    stream port : 1234
    dreamport : 80 (optional)
    the web receiver will connect with my streamer program and will display my dreambox channels as well as you should receive radio channel(my upload speed is low so difficult to stream tv channel)
    ot fill this in windows media player in file-url
    mms://drfaraj.dyndns.tv:1234
    feedback is important
    this test will be for 2hours only
  11. #446
    To demonstrate web
    Hi, success here in Latvia (near Baltic Sea) I have 10mbit DL and 512kbit upload, but media player interrupts often and show a lot of " Buffering...." and "Reconnecting.." But can see some ornaments and radio voice
    P.S. I would say that the picture is better than audio - this is more audio which disappears
  12. #447
    Nov 2008
    Hi, no success here in Latvia (near Baltic Sea) I have 10mbit DL and 512kbit upload, but media player only show " Buffering...." and "Reconnecting.."
    Did you connect with my streamer
    to receive my stream you need not high download speed and 10 mb if more than enough to receive upload speed is not important
    you can try now
    i am broadcasting bbc radio now
    just fill the information above exactly
    Now broadcasting stopped
  13. #448
    you can try now
    No i was connected with media player, but doesn't matter - here is everything working andt on Sunday i'm going to Brasil and Argentina and am very eager to know how it will work there. Hope that my home dreambox and Mac will not suffer from electricity or networking faults.
  14. #449
    Hello Boss!
    So excellent news at the end of the day - have updated the firmware of the router (Apple Air Extreme) and made a full reboot to it - and o, miracle, things back to normal - no one glitch or problem at all.
    Thank you again for the excellent and elegant solution and wish me success in Brasil for testing it at 12000 km away from home with dreambox,
  15. #450
    Nov 2008
    nice ot hear that nixus
    happy streaming
