Mfaraj If you get a solution how to get subtitles by teletext in windows media player, you would be my hero!
I tried the programm with my IPbox 400S. The programm connects fine. And from my office I can now easily reach my IPbox. But the restreaming does not start. It starts for a few seconds, and then halts again. So watching TV from my office is stil impossible. I can only switch channels (my wife does not like that). Does anybody see a solution?
TIA
JDZ
hi
dreambox viewer don't work so help me please.
This dont works for me, i have DM800, windows 7, i used to click ,,Run As administrator,, i got test connection susccesuful, and when i try to watch program i get channels, names of channels, infos of channels, and it write playing channel, but nothing happens, gray screen over and over again....
Edit: i neded to put compatibily ,,Run program on XP (SP3),, or when i dont do that i get cannot acess OEL registry (something like that )) and sometimes nothing happenes its running in process but nothingm any help ?
The program depend on vlc to receive stream from dream800
install latest version of vlc could solve the problem
sometimes the image in dreambox play role in streaming
try to run the program from right click menu-properties and choose xp sp2 compataibilty
if this not succeeded the is program play stream from dm800 with different mechanism called
mFaraj E2 player 1.0.1
Again same, playing... and nothing happening with that E player![]()
try to receive stream by dreambox webinterface webxtv could be the reason there is defect in sending streaming from the dreambox image
try also dreamstream E2 program
yeah that works but freezing :P![]()
hi mfaraj57, i am very interested with your program. i managed to down load player and streamer 6.04 and working well with my windows xp.using dm800 with nabilo black hole image. my first question is i cannot stream using reciever 5.02 on my other computer(windows vista).port 1234 and 5678 are opened (testing port checker) and dns updated. on receiver setting i typed my dns and port 1234. i can view channels from dream box clicked start streaming it says wait but nothing happens.very frustrating.2nd question how will i view your program using wmp and vlc. thanks in advance.
Hi and thanks
i will answer you tomorrow
Hi and sorry for delay
to receive stream we can use vlc,wmp or web receiver program
in vlc we can put in file-open netwrok stream and put the address appeared in streamer program
in wmp you can use file-open url and put the address
regarding web receiver just fill the dns address and port 1234 in settings
you can do this and test in streamer side and see if you receive stream,if you succeeded in receiving streaminm in same windows hosting streamer and you can not receive in remote vista pc then there is problem in vista and program
regards
