Well hib there can anyone help i am trying to flash dream box 500-c 1.1. having trouble to unzip the files i have how do i do it please help![]()
Hi mfaraj57
I am still not able to put the software working.
On the setting of the streamer when I click on the last ? to test dynamic dns and port forwading I get an error saying that my dns was not created or updated. I have used my static IP and the result was the same.
So maybe I have a problem creating this dns. Could you explain with some dettail how to created this dns?
I have created one following all the pictures that I saw on the Tunisian forum but I am not sure if I did it OK.
Dedes
PS - an update: If on the streamer server port settings I enter 1234 I get the error I mentioned but if I enter port 5678 it says it is OK
Hi dedes
you do not need dns address because you have static ip
instead filling dns address fill your static ip
you do not have to test it ,but if you want from
start-run-cmd
write this
ping dnsaddress
if it is ok it will give something like this
if not
the dns address is created but not updated
live stream of radio 3 radio channel on hotbird from dm500
upload speed(90kb/s) and transfer upload speed 8k b/s
just enter this address mms://waed.dvrdns.org:1234
in windows media player and enjoy
from 3-4 GMT sunday
now showsport from dm800 at
from 6:30 -7:30 GMT
i will not promise to get clear continuous video because streaming with low upload speed(80 kb/s and upload transfer speed 8 kb/s with 512 kb/s adsl speed
but imagine with 700 kb/s upload speed(4 mg/s adsl speed),the quality of video stream will be
Hi there
for all have faced problems with the program , port 1234 and port forwarding
please use VLC download version .99 and avoid using version 1.0.0
i advice using port 1234 because it is the vlc default
vlc version .99 download
Hello everybody!
First of all i want to say that im a big fan of ur work mfaraj57! Keep up the good work!
I just bumped into this thread and i downloaded and installed your tunisia-sat dreambox player and streamer5.0 ..
And I actually managed to stream! Locally and on the internet ... I own a Dreambox 500 with Gemini, thus i get the same blurry screen as in post #11, by mfaraj57, in this thread ...
I hope this can be fixed in the future
Once again mfaraj57 keep up the good work!
thanks Gurr
quality of video streaming depends in two things
1-Type of dreambox and the image installed on it
Pli-jade is the best for internet and local streaming while Gemini is the worst
Enigma 2 dreamboxes(dm800,dm8000,dm7025) are better regarding streaming than enigma1 dreamboxes(dm500,dm600....)
2- Internet speed
The program does transcoding(compression and conversion) for dreambox stream before restreaming to internet
this process transcoding downgrades the quality of the video stream,as much as you did compression the qaulity get worse
in program settings there are three choices ,according to your internet speed select your option
low upload speed -gives the worst stream
medium upload speed gives better streaming
high internet speed gives the best video stream quality
For all the users of this fantastic forum that cant make the mfaraj software work, please search for " Dreambox Streaming Over the Internet Using Orb.pdf " and make sure that with a PLI image to not to input all string but just the http://192.168.x.xxx:31344 without any subsequent stream info of the channel.
If you dont understand send me a pm with your landline,skype,msn and i will help you... I will not be prepared to write 100's email/messages just want to speak and look at your pc with Teamviewer. Italian and English speaking only
This problem because the program is incompatible with version vlc 1.0.0
installation of vlc .99 will solve the problem
just open port 1234 or what port you like and you do not have to check by online internet checkening tool or other method because most of them will give false results
just go to program and start streaming
Enjoy classical music from my dm500 live stream from classical radio channel-orbit arabsat
just enter in windows media player
for 1 hr from 11-12 GMT
