Page 8 of 45 FirstFirst ... 34567891011121318 ... LastLast
Results 106 to 120 of 661
  1. #106
    Nov 2008
    Quote Originally Posted by dowlinr View Post
    I had troubles with this on my laptop. I loaded it on my pc and it works but there are a few bugs (which I can live with).
    When I change the channel on my dreambox it reconnects to the stream but loses sound. I have to restart the app before sound works again.
    Another issue I have is my bouquets start with Astra 28.2e which is empty, then I have UK tv which starts with bbc1, bbc2 etc. The app seems to have added a random bouquet called 2AE which now has all the channels that should be in UKTV. UKTV now has sky movies channels, sky sports are now in my movies bouquet etc.
    This bouquet issue also happened in Dreambox viewer ver 4.0
    In all I am very impressed with the app, very good work Mfaraj
    Thanks dowlinr
    thanks also for nice pictures and demonstration
    Typically changing channels should be from application itself,however if user changes channel from the receiver the app understands that and accomdate accordingly but may behave differently in state of streaming and recording
    regarding the bouquet 2AE,the app does not add anything,The program connectes with dreambox database and brings channels and bouquets information and displays them. About the appearance of 2AE which it seems shorcut for 19.2 astra east
    i will investigate that and i will fix the problems you have faced in next version
    The program is individual effort and tested in one enviroment so bugs are expected with different enviroments
    thanks again for your positive notes
    watch live stream from my dreamboxes
  2. #107
    Top Poster + dowlinr's Avatar
    Nov 2008
    Quote Originally Posted by mfaraj57 View Post
    Thanks dowlinr
    I tested it on my laptop and desktop, both showed the 2AE so it may be an issue with my dreambox config. The webinterface for the dreambox shows the bouquets as they are in the channel list on my dreambox so not sure if it is a failure on my part setting up the bouquets or a bug in the software.
    If you need my services and bouquets files i'll zip them and upload them somewhere.
    On the channel change issue I was using the remote control, haven't tested changing channel with the receiver software as I was testing with windows media player only.
  3. #108
    Nov 2008
    Hi dowlinr
    It is important to me to have the services and bouqeuts files to study then
    please upload them anywhere and pm the link
  4. #109
    Retired Sat TV Addict
    .: JaCkPoT :.'s Avatar
    Aug 2008
    var/tuxbox/plugins
    cheers stream worked...im no too bathered about the quality man..nice one
    Read the Rules here; they apply to Everyone.
    ___________________
    In the good old days, I had
    DM800s HD
    Openbox S10
    TM500
    DM500s
    90cm FortecStar dish
    Technomate 2300 Motor
  5. #110
    Nov 2008
    Quote Originally Posted by .: JaCkPoT :. View Post
    This stream by upload speed 90kb/s imagine if it is 400kb/s
    the quality with improve ten times
  6. #111
    Nov 2008
    Do you receive the stream,now just changed the internspeed to medium from settings,the quality will improve but with inturruption
  7. #112
    Aug 2008
    var/tuxbox/plugins
    Default screenshot doesnt work
    ScreenShot doesnt work, when i press 'Print Screen' the little screen turns all black for the screen shot. i have tried over and over again..
    ___________________
    DM800s HD
    Openbox S10
    TM500
    DM500s
  8. #113
    Nov 2008
    Ok do not worry
    this behavior expected with windows media player hard acceleration put to full
    to make print screen working and screenshot just by right mouse click on small screen-options-decrease hardware acceleation to half and everything with be ok
  9. #114
    Nov 2008
    Nov 2008
    for taking screenshots and adding texts to picture i advice this nice programsnagit
    pictures above taken from snagit
    second good program to upload images
    attached with this post
    just drag the picture you want to the frog and after seconds will give you the link
    Watch streaming from dreambox by internet
  11. #116
    Nov 2008
    The problem in first item
    Astra/eurobird-28,2AE
    the comma inside the item make the program to understand this as two bouquets so add 2AE
    this rare bug in program and will fixed in next version
    for now to fix it,just from receiver remove the comma(,) from the item and everything will be correct
  12. #117
    ^^ i noticed the same bug
  13. #118
    Nov 2008
    Quote Originally Posted by gurr View Post
    Yes it is bug
    when i observed the name of bouquets for presence of comma and i did not find it
    but the expresion 28,2AE should be written 28.2AE but this error cause minor bug in my program
    solution just remove "," from the 28,2AE from receiver or from dreamset and everything will be ok
  14. #119
    Nov 2008
    Yes it is bug
    Mfaraj is right, simply changing the comma for a full stop fixed this bug for me.
  15. #120
    Member MyB5's Avatar
    Jan 2009
    Up north
    Anyone has this working with Vista Home Premium (streaming)? I'm just able to watch it on my PC (Lan)....
    Vu+ Duo-BH 2.0.9,1
    CloudIbox II+
    DM600PVR & DM500
    Skybox F5 & F5s
    Oscam 9533 & CCcam 2.2.1
    0.8/ 4.8/ 7.0/ 13.0/ 16.0/ 19.2/ 23,5/ 28,2
    Scandinavian
