After a little advice on this one before i get stuck in.
Had a call for lost keys on an Astra H today customer had the code cardalready so nice easy job I thought. Turns out its not.
Got in hazards going off turned them off and didnt think anything of it. Only had 10 volts so put a booster on it and got 13.5 volts at the obd socket. Checked fault codes with the mvp and none present. Cleared the old keys and programmed the new one no problem and the remote works fine but it wont start.
A bit of customer interegation reveals its a cat D and had a side impact front passenger seat airbag and curtain airbag have been deployed and now removed. So its in crash mode and obviously will need the airbag ecu reset and airbags replaced or emulated before i go any further.
Borrowed an op-com cable to check all the codes and i got a lot more than I was expecting.
The 4 Airbag errors I was expecting but not the other 21 fault codes!
I havent had to deal with one of these in this situation before so any advice as to weather or not the rest of the codes are related to the crash mode or not would be appreciated.
If i turn on the ignition with the key I have programmed you can hear the fuel pump prime itself and the engine turns over and the remote works. With an unprogrammed key the pump doesn't prime and the engine doesn't turn over. So surely this suggests the key is programmed but the ecu is still reporting the key as unprogrammed.
Also despite the pump priming (and yes i put fuel in it) no fuel is reaching the injectors.
Any pointers would be much appreciated before I start.
