Results 1 to 2 of 2
    Oct 2012
    Default Dm800 problem in signal
    Real problem
    AT the starting point it comes picture and then tuck showing turner failure.After that I check diseqC switch & two LNB are dead.I change LNB & diseqC switch then find same problem ( turner failure)
    I Check this box in my friend house.It is working fine with friend box (if we start two box at same time) when my friend box swith off then my box is showing turner failure
    What is real problem
    Please please please help me
    DK Veteran WOODWARD395's Avatar
    Manchester UK
    sounds as if no power to LNB to me as friends box is supplying power until switched of, have you checked voltage settings in tuner settings.
    Education is not the learning of facts, But the training of the mind to think
    So hit the thanks button if I have enlightened you.
