Results 1 to 4 of 4
    Default xprog-m with 3d33j urgent help
    please i have problem with honda accord model 2000 v6 mcu 3d33j hc05 the problem is device is silent double checked wires on board and on adapter plc 52 attached resistor on my green ocb mosfet changed oscillator value all same any ideas even tried with rs323 and power supply i tried my xprog with many mcu 9s12 micronas all fine any ideas ?
    soorry i forgot to mention dashboard and i have no other tool
    simaservis1108's Avatar
    Aug 2013
    Serbia,Belgrade
    Xprog doesn't work well with HC05 and HC08.
    Sometimes it reads first time,sometimes it won't budge.
    Best is ETL for this,or Polish HC705/711 programmer.
  4. The Following User Says Thank You to simaservis1108 For This Useful Post:
    sv2hqx (16th January, 2015)
    May 2011
    hi
    use upa and connect 4 wire like rx,tx,gnd,+volt.....and upa wire number are 2,3,5,9......read write all ok...thanks
