Page 1 of 17 12345611 ... LastLast
Results 1 to 15 of 243
    V.I.P. Member Chimaera's Avatar
    Jun 2009
    Default Guide: Getting The Best From Your 500 Series Dreambox
    Hi all
    Over the last 10 days Ive been putting together a tutorial for you all.
    Ive tried to include every bit of info i can find to make it as complete as possible.
    Hope it helps
    Have fun
    If you come across anything Ive missed pm me and ill amend it
    Update If you CANNOT Download this file it is because you have not posted in this forum, goto the introduction section make a post and wait 20 mins then all should be well
    And please DO NOT make posts about this is wrong with my box how do i sort it...that's what the general dreambox forum is for, go and read some posts
    Last edited by Chimaera; 11th August, 2010 at 10:43 AM. Reason: Added Audio Description section and updated fastscan and general tidying
  2. The Following 15 Users Say Thank You to Chimaera For This Useful Post:
    baadboy (15th September, 2014), beatricia77 (21st August, 2013), dazzle46 (7th July, 2013), deegee7456 (1st October, 2013), dingdong09 (9th August, 2013), Djinn00 (20th November, 2014), donnyvikings (5th November, 2013), maximusdreamer (9th November, 2013), ozzy30 (9th June, 2014), pfj_official (22nd October, 2013), poppyjack (24th September, 2013), robert62 (10th November, 2013), ybot (22nd August, 2013)
  3. #2
    cunny's Avatar
    Jan 2009
    The Shoutbox
    Awesome for a dreambox noob like myself thanking you
    V.I.P. Member opsmonkey's Avatar
    Nov 2008
    var/etc
    This is the best i've ever seen... Have you posted it in the Satellite Dreambox section..?
    The Stig PT mtv1's Avatar
    Apr 2008
    Tipperary
    yes even from a pro like myself well done m8
    Administrator
    Devilfish's Avatar
    Feb 2008
    /cdk
    Fantastic! A wonderful collation of guides and information, well done!
    Sticky'd!
    DK Veteran ruudvandan's Avatar
    Kathmandu
    I'm moving house shorlty and I've been thinkin about getting myself a dreambox to go in it. This will be a great help. Thanks.
    Jun 2009
    Quote Originally Posted by opsmonkey View Post
    Hmm no because its a cable guide, i was toying with adding the extra stuff for sat to it so it covered both but i know nowt about sat.
    maybe someone will advise
    Can someone confirm how many posts you need to make before being able to download?
    I joined as a complete novice to research and have a go - just ordered an openmedia 500cs hence interested in the 500 guide
    This looks like just the job but I don't have permission to download, looks like I have to post 1st but don't want to post for the sake of it.
  10. #9
    V.I.P. Member wilf's Avatar
    Jan 2009
    uk
    about 15 to 20 mins mate welcome to dk
  11. #10
    Northern Ireland
    Brilliant Guide....dreambox arrived today so i envisage a long night ;o)
    First question i've just pluged in straight out of box to see what's on there now but when i do a auto scan on the 2 transponder available to me they do not lock or sync to any channels is this normal? or should i be able to see fta based in Belfast on vm
  12. #11
    Jun 2009
    Never had a brand new image so i couldnt say
    i would suggest looking at the stickies and getting the latest image DK 1.1 i believe and install that and add the "magic" files to make it all come alive
    Reading will be your biggest asset right now
  13. #12
    Default ive f****d up my dreambox
    ok peeps ive actually killed my dreambox! Help! I was following Chimaeras guide and I was trying to flash a new DK 1.1 image which contains the hypercam fix. Now because I dont have a null cable to hand I decided to follow the telnet guide to flash the new image to temp folder in dreanbox. i followed every step successfully until telnet erased my current files but didnt open and install my new image from temp file like the guide says it should. Now i have a blank screen nothing! filezilla or telnet cant even find my ip address of the box it would appear to be completely wiped!! Any ideas please ?
  14. #13
    Jun 2009
    Quote Originally Posted by darcor View Post
    did you actually ftp your new image across before you used this command?
    If you didnt do this step and jumped to the step
    cd /tmp && eraseall /dev/mtd/3 && cp backup.img /dev/mtd/3 && reboot then yes you have deleted your image
    because the files werent there for the reboot part which is the last bit of the line.
    So you are going to have to get a null cable and follow the Dreamup section in the Howto to get going again.
  15. #14
    Junior Member alfagt's Avatar
    Sep 2008
    Hi M8,
    You will have to go back to the start again & get yourself a null modem cable & use dreamup & flash the box with the dkv1.1 image ,it is the best option. The cable is not very expensive. then you can use flash XP or Filezilla to move the rest of the files to you dreambox.
  16. #15
    thanks lads im up and running with a working dk 1.1 image and all is well
    Would just like to say a big thank you to all the regulars who give us their time and patience answering the same stupid questions over and over again. I, like so many others, will leave here now only to land back in a month or 10 when the next crisis happens and the same regulars are still here still helping and guiding us..........again thanks guys for your help and time
  17. The Following User Says Thank You to darcor For This Useful Post:
