Helo guys!
I have problem with c3 1.4kfv ecu s2pm-380, water inside ecu.That is repaired and now ecu is conectable and on diagnose i can see ecu and some parameters.Now problem is that ecu is locked.Connection between bsi and ecu is ok and when i cut can lines,bsi report error code 'not communication with engine ecu'.Pin code in ecu is same like in bsi.Tryed match key again,successfull,but ecu is still locked.In eeprom 95080 founded in first row pin is missing for some reason.I think eeprom file is damaged.Some files for immo off that i found on DK,not work at all.
Is anyone maybe have virgin flash and eeprom for this ecu,s2pm-380?
Here is original flash and eeprom readed from them.
s2pm-380.zip
