Page 1 of 4 1234 LastLast
Results 1 to 15 of 60
    puiu's Avatar
    Timisoara
    Default Fiat Ducato MJD 8F3.BD DPF off
    i need help to make DPF off ,
    Fiat Ducato MJD 8F3.BD MPC5565 2.3JTD 130PS
    i modified file with Swiftec but after few thousand km come back
    with error: P1564 Excessive distance traveled by light DPF ON,
    and error can not be erased,
    i put orig file back,and made forced regeneration,
    all error are gone,
    i put back the DPF off file and after few thousand km came back with same error...
    please help,
    Puiu
    Dec 2013
    I know, swiftech solution don't work properly. I done first with switches and looked fine but after thousand km, as you told, check engine came out and gave P2002 I think. After that I used another solution that work withou problem.
    It's not a easy ecu this MJD 8F3
    Hi!
    Would you like to share pinout for Galletto v54?
    Thanks.
    luca22's Avatar
    Dec 2010
    Hello
    Here You are
    I do that ECU six times,by galletto V54 EU and 100% ok
    Luca
    PLEASE PUSH THE BUTTON THANKS IF MY WORK HAS HELPFULL
    AND REPUTATION BUTTON (starr)
  5. The Following 3 Users Say Thank You to luca22 For This Useful Post:
    capi (10th May, 2017), eculevel (13th October, 2017), Stelaras26 (8th January, 2022)
    Feb 2016
    Quote Originally Posted by puiu View Post
    all error are gone,
    please help,
    Puiu
    Hello. Ihave the same problem. Did you solve you problem?
    With Kess is simple...it's by OBD and it worked good with swiftec solution...
    Sep 2016
    swiftec its not good solution....... car back
    FILE SERVICE
    Feb 2016
    Before writing I reset DPF. But car came back with p1564. Maybe there is some counter in instrument cluster? Please help.
  10. #9
    Sep 2016
    good solution is there when you show with parameters dpf strokes, swiftec never cut good dpf in 8f3
    FILE SERVICE
  11. #10
    Feb 2016
    I haven't swiftec solution. My solution from damos. Maybe you can tell me what i need to change. Thank you. Damos in attach.
  12. The Following User Says Thank You to dusichek2012 For This Useful Post:
    nbtechnic (28th April, 2017)
  13. #11
    Sep 2016
    sorry but i dont teach
    FILE SERVICE
  14. The Following User Says Thank You to voltechcar For This Useful Post:
    NiZaTroniC (6th December, 2017)
  15. #12
    ohkarol's Avatar
    Oct 2010
    PL/UK
    i have done few with swiftec and till now cars not coming back. You need to reset dpf filter berfore flashing dpf off file.
  16. The Following User Says Thank You to ohkarol For This Useful Post:
    puiu (20th October, 2016)
  17. #13
    Feb 2016
    I reset filter before writing. Can you give me example of swiftec solution mjd8 ? Thank you
  18. #14
    Act Tuning's Avatar
    Sep 2016
    Around
    Check the latest update from swiftec, i test some and it tested, and if you have a problem open a ticket and they will mod it,
    CVN FIX Vag/Bmw
    Tuning Petrol and Diesel
    High Power Maps
    Custom Tuning Stage 3+ Hybrid
    Dsg Tuning
  19. #15
    Feb 2016
    I haven't swiftec, that's why i ask you.
