hi i am new to enigma 2 boxes , i have bought a zgemma s2 could anyone help me get my box to connect fo filezilla on my pc please .
First you need to find the IP that has been allocated to the receiver generally Menu - setup - Network - adaptor settings should find this out for you example 192.168.xxx.xxx
enter the given IP into filezilla and the username 'root' normally images are not passworded
press connect
cactikid (26th April, 2015)
Good Morning All
After some support from digicon I think I'm about done. Just stuck on the last hurdle and need a push in the right direction.
Auto Bouquets
Zgemma H1 both tuners set up all and working, usb plugged in back formatted and also mounted
The sticky part is this next bit :
Menu/set up/ service searching auto bouquet maker
Configured expert-providers set up-start scan
Loading bouquets
Reading sly
Services 590 radio 61
Tuning vermin
Then this message
Time out for tuner lock !!!
Could someone please let me know what I am doing wrong. Thank u in advance
ps sorry if I gave put this in the wrong post
You need to enter your Net ID frequency in the Service Searching part of the main menu, without this Autobouquets will not scan in your local channels
What's the cable tuner like on these? Been trying to set an old DM500c up for my old man, but the BER is through the roof. Will this be more stable?
Well said cacti kid, in possession of a bricked clone Icloud myself... having used the online update feature unwittingly.
They seem to come with everything including a self-destruct mechanism.
Last edited by satsmo; 28th April, 2015 at 09:50 PM. Reason: Removed provider reference
Have full ver Ross-Tech Vag Com.
I have edited your post, please review our rules once again.
I refuse to answer that question on the grounds that I don't know the answer. - Douglas Adams
digicon (29th April, 2015)
Alright so I got both of my units in and they work on the clear channels with DVB-C, however if I start scan at 231mhz (with network scan on), it only picks up the channels from that. Then I go over to 285mhz and do scan again (make sure clear is no) and it picks up the rest of the channels but the channels from 213mhz get deleted. I'm stumped
that sounds like you are scanning 1 frequency for channels,but would need to auto scan all the frequencies,wonder if there is a brute force scan on that cable side to use?
I got it. You need to go to channel list and select all providers. Kinda non-intuitive.
This box is really decent
The only other thing is see if I can get ViewMatrix working. But that might be a lost cause and its against the rules here
