Page 41 of 48 FirstFirst ... 313637383940414243444546 ... LastLast
Results 601 to 615 of 720
  1. #601
    Talleresmalaga's Avatar
    Nov 2017
    Espaņa
    Quote Originally Posted by mmgherasim View Post
    Hello, guys! Can this FVDI be updated to a newer version? I mainly use it for VAG cars and I have latest working Vag Loader v21. Is there anything new to update to and worth it? When I bought it, I got it with FVDI 2014, 2015 and 2018 versions, but only 2014 worked. 2018 was saying: "Connectinng to server.... OK" and immediately after: "Device not opened". Can it be flashed to work with 2018? Thank you!
    Attachment 703223
    For 2018
    I try to close the window connecting to the server, before the countdown, disconnect the interface?
    it works for me
    Has anyone tried these connectors in fvdi 2018?
    Could this and other connectors be used like those of motorcycles that did not come in the pack?
    https://www.mk3.com/abrites-adapter-...36-zn045-zn033
    best regards
    If help is useful thanks+rep
  2. #602
    Feb 2016
    Hello! I have the original Abrites AVCI, with 2010 software. Could I update it to FVDI?
  3. #603
    Mar 2017
    RO
    Quote Originally Posted by pacurar View Post
    Hi I have an FVDI 2014 which has a problem on the k-line at edc15, it identifies correctly identifies ecu and after a few seconds it disconnects and a message "connection lost" appears.On CAN it works perfect. I have change the L9637D and the ADG1406BRUZ but stiil no result for the K-line problem.
    We changed all MOS relays with OMRON 61g1 relays
    I tried on several PCs and I tried with more edc15 and more instruments cluster, same problem with k-line.
    Can this problem be resolved?
    does anyone have any idea about my problem ??
  4. #604
    Oct 2010
    Default TEST_BOOT+Prog.rar
    Can you send me the pass for this this TEST_BOOT+Prog.rar?
    Regards, NACKOM
  5. #605
    I have AVDI 2015 softdog red dongle and I', using loader v.9.0. It connects to server and then there's a message device deactivated and spawn app failed. Any suggestions?
  6. #606
    electronistul21's Avatar
    Nov 2011
    galati,romania
    open case from unit and measure voltage battery.if is under 3Volts,your is died because lost syncronization and need reflash LPC.
    Carprog 8.21,xprog 5.55,galletto v54,kess and ktag rework
  7. #607
    Battery is OK. It says days remain 0 and can't connect to interface.
  8. #608
    Jun 2017
    Default need pass
    Thanks !! need pass for TEST_BOOT+PROG.rar
  9. #609
    May 2020
    Thanks Thanks
  10. #610
    BIH
    I need pass for TEST_BOOT+PROG.rar
    Tanks a lot
  11. #611
    Jun 2014
    Hi BRos
    the topic i want to say is old but problem is still valid for meny people. FVDI K-line does not work . I have read all posts and step by step tried fix. No one way help me but Micromax idea only, thx so much. My FVDI is as FORMEL ONE now. What i have noticed, it works better/faster then another one whitout modification ( i have a few pieces ). Unbelievable . thx so much for all.
  12. #612
    Quote Originally Posted by crashowag View Post
    We all do...
  13. #613
    fred77's Avatar
    Jun 2019
    Quote Originally Posted by marwo View Post
    Hi BRos
    how can it be unbelievable? Sounds like Fly is using shit components.
    And can't be faster.
    Anyway even the original AVDI the multiplexer was only rated at 15V. Scary when consider flashing volts is around 14V.
    Yeah this is why AVDI is all going on-line to stop these cheap clones God i hate Fly
  14. #614
    Jul 2020
    Quote Originally Posted by user2468 View Post
    Please dont try to reflash your FVDI if it is working OK!
    Try to write this fvdi boot v1.0 hex file via uart, maybe help.
    Pass for Boot+Prog hex file pres Thanks + Rep.
    To prog. the LPC1788 use MagicFlash + FTDI USB to TTL Serial Adapter 3.3V
    Connections Here:
    https://www.digital-kaos.co.uk/forum...=1#post2530475
    Hi, any chance of pass pls?
  15. #615
    Aug 2020
    Constanta / RO
    Hello. I have problem with FVDI2014 clone. Since yesterday, interface work good (from 2 yrs). Now, I can`t diag over Kline and CAN. It`s not driver or sw problem. Interface was found but I get communication error on OBD and also in Bench !
    What I need to change ? I found only this ... Thanks and I`m waiting answer in case if I missed another component.
    U13 : ADG1406BRUZ
    U10 and U11 : ADG1404YRUZ
    U14 : L9637D
    U12 : AU5790D
    K7 : Omron G3VM-61G1
