Page 45 of 48 FirstFirst ... 35404142434445464748 LastLast
Results 661 to 675 of 720
  1. #661
    Aug 2008
    this on windows xp ? or you trying to use it on windows 7 or higher?
    iv only used mine with xp and always been fine
    also did you try to use other software instead of the one it came with?
    other than that did you try to do an update?
    all the above is bad except the part about using xp only
  2. #662
    Nov 2020
    Quote Originally Posted by palsw View Post
    please me
    no work fvdi
    calibrated
    soft 2014
    it is bad, need to return back to factory to repair
  3. #663
    Mar 2019
    Izmail Ukraine
    Quote Originally Posted by tango View Post
    Hello.
    I use wines 7 x32
    I was given this device, without software on the disk. It was bought for a long time in 2013-2014. It does not have a softdog. The program on the laptop did not run the native Commander V2.2. On this new version 2014 TAG and a few more brands are working. Perhaps this is not FULL. can I flash it for FULL 2014?
  4. #664
    Aug 2008
    dont flash it or even try to, it will kill it
    if you have some working then all you need is the correct software for the unit
  5. #665
    Jan 2020
    hello everyone! I have fvdi 2018 clone with the same problem .can someone help me with a flash depending on the lpc1788 processor id? thank you in advance ...
  6. #666
    Nov 2020
    Quote Originally Posted by nykky79 View Post
    FVDI 2015, 2016, 2018, 2019, fvdi 2 and all version SVCI all are online version.
    They always were blocked anytime by STIC company zhu engineer.
    FVDI 2015, 2016, 2018, 2019 ,FVDI 2 and all version SVCI with a battery
    When the battery dies, the device will be locked
  7. #667
    Feb 2018
    svci 2019 and svci2020 they do not have a battery and do not have to be online, to extend activation every 29 days, while these older versions 15,16 and 18 have a battery and must be connected to the internet every 29 days and can be blocked at any time
  8. #668
    Nov 2020
    Quote Originally Posted by zoki21 View Post
    Help me for this problem svci 2020
    https://www.facebook.com/groups/1844...06432682827165
  9. #669
    Nov 2020
    svci is trash can.jpgif it doesn't work, I suggest visiting the nearest garbage can.jpg
  10. #670
    Feb 2018
    Well, not everyone can do all brands of cars, it's still a copy, but you can do a lot, buy yourself an original, so when you have such a problem, let the support solve it.
  11. #671
    Jan 2020
    When the battery dies,the devicewill be locked .ok.which is the solution in this case, thanks
  12. #672
    Nov 2020
  13. #673
    Jan 2016
    please pass to TEST_BOOT+PROG.rar
  14. #674
    Dec 2015
    thank you verymuch
    pass please.
  15. #675
    Mar 2018
    pass pls for TEST_BOOT+PROG.rar
