Page 1 of 49 12345611 ... LastLast
Results 1 to 15 of 721
    gopelhu's Avatar
    Jan 2010
    EU
    Default AVDI or FVDI pcb components
    Hi all,
    I started this thread, because I need more information about FVDI interface.
    I was already a picture of the top sides but there should be a picture of the bottom side.
    Do I need a parts list of all the components.
    If anyone can, pls help me.
    Regards, G
  2. The Following 7 Users Say Thank You to gopelhu For This Useful Post:
    Brinner (30th November, 2022), canisha (9th January, 2022), Col19 (25th October, 2019), makadam (28th December, 2022), MCLP750 (5th May, 2020), spajdermen (8th February, 2021)
  3. #2
    DK Veteran kelekele's Avatar
    Apr 2010
    Sonta,Serbia
    This picture of botom side, from what version is?FVDI ver 3 and 4 not have bottom components.
    All components marked and on internet you can find their usage.
    ADG1406BRUZ-16 channel multiplexer ,etc...
  4. The Following 2 Users Say Thank You to kelekele For This Useful Post:
    Col19 (25th October, 2019), gopelhu (17th January, 2015)
  5. #3
    gopelhu's Avatar
    Jan 2010
    EU
    Version is V4.
    I need the flash and ram components.
    If you have V3 bottom side, then i need it.
    Regards, G
  6. #4
    bursuc's Avatar
    Oct 2011
    inside MCU
    What improvements will be if all components are changed ? Anyoane try it ?
    Best regards
    Dosen't matter how hard is to repair something as long is made by humans and thinked by humans !
  7. #5
    gopelhu's Avatar
    Jan 2010
    EU
    For now, I do not want to talk about the development, only if I already have the results.
    Please be patience...
  8. The Following User Says Thank You to gopelhu For This Useful Post:
    kelekele (18th January, 2015)
  9. #6
    Apr 2010
    Sonta,Serbia
    My fvdi has problem with K-line voltage drop and can communication with some cars.Solved with change adg1406bruz multiplexer ic.
  10. The Following 2 Users Say Thank You to kelekele For This Useful Post:
    gopelhu (18th January, 2015), JarsaR (5th June, 2017)
  11. #7
    gopelhu's Avatar
    Jan 2010
    EU
    Thanks for the info, but my project is the different solution.
    I need these IC's number ( one static ram, one flash).
    If anybody know pls let me know.
    Regards, G
  12. #8
    ovi_dk's Avatar
    Jul 2010
    On board
    U can see here pictures with fvdi
    http://www.digital-kaos.co.uk/forums...highlight=fvdi
    If u have the answer say Thank You!!
  13. The Following 3 Users Say Thank You to ovi_dk For This Useful Post:
    Col19 (16th October, 2019), gopelhu (20th January, 2015), JarsaR (5th June, 2017)
  14. #9
    gopelhu's Avatar
    Jan 2010
    EU
    Thank you so much the info.
    Regards, G
  15. #10
    gopelhu's Avatar
    Jan 2010
    EU
    Hi all,
    Here are some info the parts, if anybody need them.
    Regards, G
  16. The Following 71 Users Say Thank You to gopelhu For This Useful Post:
    21Leonardo (4th March, 2023), AGDiag (16th March, 2016), amor89 (12th March, 2017), arti1 (3rd January, 2019), beongo (4th April, 2015), Bishop c4 (22nd January, 2015), BlacksunLE (4th May, 2020), boxsport (9th September, 2019), brodaty (30th January, 2015), bursuc (26th January, 2015), carbonat (3rd April, 2023), carsoftobd (27th January, 2016), Charlieb1 (28th April, 2021), Col19 (5th October, 2022), CorradoG60 (20th April, 2020), duxor (14th December, 2017), electronicdeivi (30th June, 2024), estwood68 (10th January, 2020), fidodin (28th May, 2017), fifii69 (22nd January, 2015), foskr (6th May, 2020), glk96000 (28th May, 2015), hbalazs (24th January, 2015), hhp (17th June, 2023), JarsaR (5th June, 2017), jnoroeste (31st January, 2015), joe06 (14th April, 2018), k1champion (8th March, 2017), koki (16th January, 2018), lanefi (11th November, 2018), line44 (3rd August, 2019), makadam (28th December, 2022), marcel cirozz (20th August, 2016), marsete (29th April, 2017), martinracing (2nd July, 2020), mercis (20th January, 2015), missfixit (30th November, 2018), moky (17th December, 2015), muzikisme (15th December, 2015), n599fbm (24th March, 2023), nelumuresan (11th June, 2016), NONO59 (6th November, 2021), ntom (7th July, 2016), ovi_dk (21st January, 2015), Papiti56 (29th November, 2015), professzor (23rd January, 2019), racin-snake (22nd January, 2015), Ray6K (13th March, 2021), remhonda (25th February, 2017), Romanki (21st May, 2022), rrguillaume (6th February, 2015), rtbdiagnostic (22nd September, 2019), scaro (9th April, 2019), seal777 (12th May, 2019), sep382 (8th July, 2021), Siham (22nd January, 2015), stas12 (22nd May, 2018), stefaudio (16th December, 2015), Tachotony (20th November, 2023), tamer1024 (4th September, 2016), tinchocbr (2nd May, 2016), trakilacee (25th November, 2015), u.s (30th January, 2015), urcarpc (4th April, 2023), V50Volvo (2nd March, 2023), vavrich (7th July, 2020), vsanyi (9th August, 2017), wojtech (4th June, 2018), XmoDDeR (21st January, 2015)
  17. #11
    gopelhu's Avatar
    Jan 2010
    EU
    Hi all
    2nd parts list here.....
    Regards, G
  18. The Following 55 Users Say Thank You to gopelhu For This Useful Post:
    2m2c (6th May, 2018), AGDiag (16th March, 2016), amor89 (12th March, 2017), arti1 (3rd January, 2019), ayoub3030 (19th February, 2015), Bishop c4 (22nd January, 2015), BlacksunLE (4th May, 2020), boxsport (9th September, 2019), brodaty (30th January, 2015), Brown012 (25th January, 2021), bursuc (22nd January, 2015), carbonat (3rd April, 2023), carsoftobd (27th January, 2016), Col19 (16th October, 2019), CorradoG60 (20th April, 2020), electronicdeivi (30th June, 2024), estwood68 (8th April, 2021), fifii69 (22nd January, 2015), frappes (10th June, 2023), geeroam (16th June, 2018), glk96000 (28th May, 2015), hhp (17th June, 2023), hugos31 (11th May, 2015), JarsaR (5th June, 2017), jnoroeste (31st January, 2015), lanefi (11th November, 2018), marcel cirozz (20th August, 2016), marsete (4th March, 2018), martinracing (2nd July, 2020), missfixit (30th November, 2018), moky (17th December, 2015), monzz (30th March, 2020), n599fbm (24th March, 2023), NONO59 (6th November, 2021), ntom (7th July, 2016), ovi_dk (21st January, 2015), professzor (23rd January, 2019), racin-snake (22nd January, 2015), Ray6K (13th March, 2021), remhonda (25th February, 2017), rtbdiagnostic (22nd September, 2019), seal777 (12th May, 2019), stas12 (22nd May, 2018), Tachotony (20th November, 2023), tamer1024 (4th September, 2016), tinchocbr (2nd May, 2016), trakilacee (25th November, 2015), u.s (30th January, 2015), urcarpc (4th April, 2023), V50Volvo (2nd March, 2023), wojtech (4th June, 2018), xanubysx (24th March, 2015), Zhenya731 (21st March, 2020)
  19. #12
    Dec 2012
    EU
    what you gona bild fvdiiii for 99.99dolars full kit
    Auto Locksmith,Tuning,Dpf Removal,Dtc Removal,Immo Removal,Ecu Adaptation,Crash Data-Clear.
  20. #13
    impactops's Avatar
    You want to be in a position where you can modify the original software to work with the clone, that way you can get a copy of the original software from people who are willing to provide it (regardless of it being interface specific) and modify it to work
    Easier said than done
    Regards
    Impactops
  21. The Following 2 Users Say Thank You to impactops For This Useful Post:
    car_soft_gorj (19th January, 2016), gopelhu (22nd January, 2015)
  22. #14
    gopelhu's Avatar
    Jan 2010
    EU
    Hi all,
    My project is a my project, not for sale.
    I working some projects, but only for me !!!
    If anybody need some info that you interface are damaged, i will help them all members.
    This is the forum, NOT an eBay...etc.
    Regards, G
  23. The Following 23 Users Say Thank You to gopelhu For This Useful Post:
    antonypaul (1st March, 2015), ayoub3030 (2nd February, 2015), bawareca (18th February, 2015), blond1 (17th February, 2016), bouizanne (18th May, 2017), brodaty (11th February, 2015), bursuc (22nd January, 2015), car_soft_gorj (19th January, 2016), Col19 (5th October, 2022), faizal (5th April, 2018), ferval (7th September, 2024), gezame (13th March, 2015), gigimercedes (27th January, 2015), glk96000 (28th May, 2015), HeXeN (21st June, 2015), krimo06 (22nd April, 2015), lidons (22nd January, 2015), makadam (28th December, 2022), marwo (6th June, 2020), Samsara (3rd July, 2017), SerjjSV (28th September, 2022), urcarpc (4th April, 2023), user2468 (26th February, 2015)
  24. #15
    gopelhu's Avatar
    Jan 2010
    EU
    Default pics
    Hi all,
    These dissasembling are very iterested !!!!
    Please check the attachment.......
    How is that possible?
    Regards, G
  25. The Following 17 Users Say Thank You to gopelhu For This Useful Post:
    666_devil (3rd April, 2016), antonypaul (1st March, 2015), automan (22nd January, 2015), bobbik (20th October, 2016), canisha (9th January, 2022), Col19 (5th October, 2022), ferval (7th September, 2024), MACKIE (30th January, 2015), makadam (28th December, 2022), MOBILTRONIC (24th February, 2017), morfej (4th February, 2015), natcorporation (20th July, 2015), ovi_dk (22nd January, 2015), pandora6 (11th January, 2022), urbajs (9th May, 2018), Zapp (4th December, 2017)
