Page 44 of 48 FirstFirst ... 3439404142434445464748 LastLast
Results 646 to 660 of 720
  1. #646
    Sep 2013
    تم الإرسال من Redmi Note 6 Pro باستخدام Tapatalk
  2. #647
    Sep 2013
    Quote Originally Posted by LABA331 View Post
    Good day,
    Message shows when try to use my FVDI. I have already checked flyobd for this issue. Apparently I need bin files to provide Machine SN. I'll keep you posted on solved....hopefully !!!!
    Where can find kver and gopelhu?
    Hello friend
    I'm waiting for you
    Please send the bin file
    Thank you so very much
  3. #648
    Sep 2013
    Quote Originally Posted by user2468 View Post
    Please dont try to reflash your FVDI if it is working OK!
    Try to write this fvdi boot v1.0 hex file via uart, maybe help.
    Pass for Boot+Prog hex file pres Thanks + Rep.
    To prog. the LPC1788 use MagicFlash + FTDI USB to TTL Serial Adapter 3.3V
    Connections Here:
    https://www.digital-kaos.co.uk/forum...=1#post2530475
    Hi, any chance of pass pls?
  4. #649
    Sep 2013
    Connections Here:
    can yo give me password for rar thanks
  5. #650
    Sep 2013
    Quote Originally Posted by r420 View Post
    I can repair your FVDI: problem SN:00000. Priv
    Can you repair my interface?
  6. #651
    Sep 2013
    Quote Originally Posted by gopelhu View Post
    Hi all,
    so thanks for some members that they answered some messages........
    now i answering some question, pls understand for me anybody.......
    1.) FVDI V2015 or higher with softdog versions:
    If the pc cannot detecting any fvdi's then the LPC1788 processor was erased ( the Quickloader v6.3 and v7.0 will erasing the LPC processor ).
    always erasing are the following two address: 0x00000000-0x00047FFF or 0x00000000-0x0007FFFF , pls check the attacment.
    After the FVDI died bec there are no has a BOOT sector and the some firmware rows. Still i working on this solution.
    2.) if you cannot bought any FVDI's from FLY Company, then the pc will go to internet then always erasing all FVDI LPC processors by FLY server !!!!!
    3.) I solved all algorithms to fvdi firmware encrypting/decrypting and now i looking the 8bytes key to v2015 version. pls be patience anybody's.....
    Regards, G
    PHi friend please help me fix this device fvdi 2018 i have the same problem, thank you very much
  7. #652
    May 2016
    [QUOTE = user2468; 3498767] Please dont try to reflash your FVDI if it is working OK!Try to write this fvdi boot v1.0 hex file via uart, maybe help.
    Connections Here:
    Pass pls
  8. The Following User Says Thank You to des7577 For This Useful Post:
    Col19 (13th January, 2021)
  9. #653
    Nov 2020
    FVDI 2015, 2016, 2018, 2019 ,FVDI 2 and all version SVCI with a battery
    When the battery dies, the device will be locked
  10. The Following User Says Thank You to flyfvdi For This Useful Post:
  11. #654
    Col19's Avatar
    Jan 2019
    France
    Hi friends
    Thank you friend Fly for your answer, the question is, if the battery does not finish the device could last? if so, it suffices to solder a second battery in order to avoid the end of the tool's life. If a friend has a solution without battery I would be happy, thanks in advance.
  12. #655
    Nov 2020
    Quote Originally Posted by Col19 View Post
    Hi friends
    when you soldered a second battery, the device already was blocked
  13. #656
    Nov 2020
    Help me for this problem svci 2020
    https://www.facebook.com/groups/1844...06432682827165
  14. #657
    pls send pass for this file
    Connections Here:
  15. #658
    Col19's Avatar
    Jan 2019
    France
    Hi friends
    For tools with a battery, just add another battery using a 3.7V 18650 battery (much more durable than the round battery) which you lower to 3.3V with an AMS1117 mini voltage regulator module. To charge this 18650 battery you will need a mini TP4056 module using a micro usb 5V connector simply
    It is a small DIY assembly to carry out to keep the tool as long as possible.
    Good job
  16. #659
    Mar 2019
    Izmail Ukraine
    please me
    no work fvdi
    calibrated
    soft 2014
  17. #660
    Mar 2019
    Izmail Ukraine
