[QUOTE = user2468; 3498767] Please dont try to reflash your FVDI if it is working OK!Try to write this fvdi boot v1.0 hex file via uart, maybe help.
Pass for Boot+Prog hex file pres Thanks + Rep.
To prog. the LPC1788 use MagicFlash + FTDI USB to TTL Serial Adapter 3.3V
Connections Here:
https://www.digital-kaos.co.uk/forum...=1#post2530475
Pass pls
Col19 (13th January, 2021)
FVDI 2015, 2016, 2018, 2019 ,FVDI 2 and all version SVCI with a battery
When the battery dies, the device will be locked
Hi friends
Thank you friend Fly for your answer, the question is, if the battery does not finish the device could last? if so, it suffices to solder a second battery in order to avoid the end of the tool's life. If a friend has a solution without battery I would be happy, thanks in advance.
Help me for this problem svci 2020
https://www.facebook.com/groups/1844...06432682827165
Hi friends
For tools with a battery, just add another battery using a 3.7V 18650 battery (much more durable than the round battery) which you lower to 3.3V with an AMS1117 mini voltage regulator module. To charge this 18650 battery you will need a mini TP4056 module using a micro usb 5V connector simply
It is a small DIY assembly to carry out to keep the tool as long as possible.
Good job
