Results 1 to 7 of 7
    Jan 2015
    Default USBLoader wornt recognise USB HDD but accepts USB Sd Card ?
    Hi guys, looking for some help (complete noob at softmod but IT literate!)
    Used ModMii to hack my Wii last week - all went well, and at the time I used a 2GB SD card as the internal SD, and an 8GB SD Card in a generic USB converter as the HDD. This works well and I can launch titles and play the ok on the USB SD Card (fromatted FAT).
    I purchased a 160GB 2.5 SATA HD and put it in a generic case to use in place of the 8GB SD Card - formatted FAT32 with 32K clusters, and copied over the files from the SD card. However the Will wont recognise the Hard Disk - launching USBLoader gives the splash screen, then a black screen, then the rolling wii symbols and back to main menu.
    I realise that the HD may genuinely not be compatible (it only cost me ?6 on AVFORUMS so no big loss) but before I write it off I wondered if someone can suggest anything I coult try and check.change ?
    Syscheck is :
    sysCheck v2.1.0b19 by Double_A and R2-D2199, Nano
    ...runs on IOS58 (rev 6176).
    Region: PAL
    System Menu 4.3E (v514)
    Priiloader installed
    Drive date: 2007.02.13
    Homebrew Channel 1.1.2 running on IOS58
    HomebrewFilter ist nicht installiert
    Hollywood v0x11
    Console ID: 76055292
    Boot2 v4
    Found 71 titles.
    Found 49 IOS on this console. 4 of them are stub.
    IOS4 (rev 65280): Stub
    IOS9 (rev 1034): No Patches
    IOS10 (rev 768): Stub
    IOS11 (rev 16174): Trucha Bug, NAND Access
    IOS12 (rev 526): No Patches
    IOS13 (rev 1032): No Patches
    IOS14 (rev 1032): No Patches
    IOS15 (rev 1032): No Patches
    IOS16 (rev 512): Stub
    IOS17 (rev 1032): No Patches
    IOS20 (rev 16174): Trucha Bug, NAND Access
    IOS21 (rev 1039): No Patches
    IOS22 (rev 1294): No Patches
    IOS28 (rev 1807): No Patches
    IOS30 (rev 16174): Trucha Bug, NAND Access
    IOS31 (rev 3608): No Patches
    IOS33 (rev 3608): No Patches
    IOS34 (rev 3608): No Patches
    IOS35 (rev 3608): No Patches
    IOS36 (rev 3608): No Patches
    IOS37 (rev 5663): No Patches
    IOS38 (rev 4124): No Patches
    IOS40 (rev 16174): Trucha Bug, NAND Access
    IOS41 (rev 3607): No Patches
    IOS43 (rev 3607): No Patches
    IOS45 (rev 3607): No Patches
    IOS46 (rev 3607): No Patches
    IOS48 (rev 4124): No Patches
    IOS50 (rev 16174): Trucha Bug, NAND Access
    IOS51 (rev 4864): Stub
    IOS52 (rev 16174): Trucha Bug, NAND Access
    IOS53 (rev 5663): No Patches
    IOS55 (rev 5663): No Patches
    IOS56 (rev 5662): No Patches
    IOS57 (rev 5919): No Patches
    IOS58 (rev 6176): USB 2.0
    IOS60 (rev 16174): Trucha Bug, NAND Access
    IOS61 (rev 5662): No Patches
    IOS62 (rev 6430): No Patches
    IOS70 (rev 16174): Trucha Bug, NAND Access
    IOS80 (rev 16174): Trucha Bug, NAND Access
    IOS202[60] (rev 65535, Info: hermesrodries-v6): Trucha Bug, NAND Access, USB 2.0
    IOS222[38] (rev 4, Info: hermes-v4): Trucha Bug, ES Identify, NAND Access, USB 2.0
    IOS223[38+37] (rev 4, Info: hermes-v4): Trucha Bug, ES Identify, NAND Access, USB 2.0
    IOS224[57] (rev 65535, Info: hermesrodries-v6): Trucha Bug, NAND Access, USB 2.0
    IOS236[36] (rev 65535, Info: rev 3351): Trucha Bug, ES Identify, NAND Access
    IOS249[56] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
    IOS250[57] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
    IOS254 (rev 65281): BootMii
    BC v6
    MIOS v10
    Report generated on 2015/01/18.
    Any ideas / suggestions greatfully accepted ...
    DK Veteran Keithuk's Avatar
    Aug 2010
    England
    I haven't been on here for a week as the site with a 404 File Not found hasn't been available for maintenance, I changed the link now I can find this section.
    There isn't much wrong with that sysCheck. If you want to remove that IOS16 Stub then install my cIOS16-v257 this link doesn't show now so I've added it to this thread.
    ModMii only installed 2 d2x v8.0 wads download d2x v8 Final wad pack and put these in the wad folder on the SD card, install all 7 wads.
    Invest in a compatible mains powered HDD.
    Keith
    2010 Golf GTD (170)
    Jan 2015
    Thanks,
    I'll give it a try - seems to work ok from a 32GB memory stick (copied contents of 8GB SD Card including 3 games in wbfs folder), until I add any new games with WiiBackupManager into the wbfs folder at which point the games hand during launching or when downloading covers for the new games).
    I'll apply your suggested updates and try again.
    BTW, what is the IOS16 used for ?
    Aug 2010
    England
    If you look in Multi Mod Manager (MMM) that will show a list of all wads and their functions.
    IOS16 - Mothballed, v257 from Wii Pink Fish Backup Disc, used for downgrade hacks.
    Keith
    2010 Golf GTD (170)
    Jan 2015
    Thanks, Really frustrated now. games that were on original 8GB SD Card work fine on 32GB memory stick (after appplying the WADs you suggested), but new ones added dont run and I cant even donload the artwork for them onto the 32GB USB key. It almost as if its operating read only ?
    Aug 2010
    England
    Well if USB Loader GX doesn't download the game pics I use http://www.wiiboxart.com/pal.php you either search for the game name or game ID number.
    I still say you need a mains powered HDD as SD cards and flash drive don't have enough room even if you buy the expensive large ones.
    Keith
    2010 Golf GTD (170)
    Jan 2015
    Thanks, setting up a spare will to leave at my dads for the kids, so just wanted to put about 20 games on, so a 32GB card should be fine - dont want the expense of an external 3.5" Hard disk if I can avoid it ...
