hanky05 (29th September, 2016)
mk60ec1 esp module
vag number 1K0907379BJ
1.6 77kw 2011 bluemotion. golf 6
I also have the same Problem.
It is a 2004 1.9 TDI Touran. ABS is going to be 1K0907379BE. Steering wheel is left, no start/stop. Brakes front are 288mm, Brakes back are 260mm.
VIN is WVGZZZ1TZ4W036571
Would be very Grateful!!!!!
Any help with this one please
vin WV1ZZZ2KZDX085146
1K0 907 379 BK
RHD
2013 Caddy 1.6 tdi
MK60EC1 with ESP
hanky05 (29th September, 2016), smirnoff_rules (28th September, 2016), smokinjoe (28th September, 2016)
Thanks a million for fast response smokey,worked a treat,was worth putting in the overtime![]()
not working
Hope someone can help have a Caddy 2K right hand drive, the ABS mk60ec1 and 2.0CR motor from Golf mk6 have been fitted to it but need coding for the ABS pump can anyone help?
Thursday,06,October,2016,10:31:14:00453
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 16.8.2.3 (x64)
Data version: 20160926 DS261.0
www.Ross-Tech.com
VIN: WVWZZZ16ZDM045609 License Plate:
Chassis Type: 16 (7N0)
Scan: 01 03 08 09 15 16 17 19 25 40 42 44 46 52 56
VIN: WVWZZZ16ZDM045609 Mileage: 233360km-145003miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: Malfunction 0010
40-AC Compressor -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 0010
61-Battery Regul. -- Status: Malfunction 0010
Address 01: Engine (J623-CFFB) Labels: 03L-906-018-CFF.clb
Part No SW: 03L 906 018 HW: 03L 907 309 R
Component: R4 2,0L EDC H25 9818
Revision: 42H25--- Serial number: 00000000000000
Coding: 00190010042500080000
Shop #: WSC 00066 123 00190
ASAM Dataset: EV_ECM20TDI01103L906018 003011
ROD: EV_ECM20TDI01103L906018_003_VW36.rod
VCID: 67DDDE9F9E6C117A15-8032
4 Faults Found:
4875 - Coolant Pump 2
P261A 00 [039] - Open circuit
Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 233363 km
Date: 2000.00.00
Time: 17:15:32
Engine speed: 779.50 /min
Normed load value: 28.2 %
Vehicle speed: 0 km/h
Coolant temperature: 67 ?C
Intake air temperature: 25 ?C
Ambient air pressure: 1020 mbar
Voltage terminal 30: 13.920 V
Unlearning counter according OBD: 40
Coolant temperature at radiator outlet: actual value: 31.4 ?C
Bypass valve for EGR cooler: status-Bit 0: 1
Exhaust gas recirculation: shut-off conditions-Bit 0: 0
Exhaust gas recirculation: shut-off conditions-Bit 16: 0
Exhaust gas recirculation: shut-off conditions-Bit 24: 0
Exhaust gas recirculation: shut-off conditions-Bit 8: 7
EGR cooling function: status-Bit 0: 0
Exhaust gas recirculation (EGR) cooler pump: specified value: 80.00 %
Temp sensor for EGR after cooler: raw value: -270.6 ?C
Exhaust gas temperature sensor 1: 20.0 ?C
5111 - Oxygen (Lambda) Sensor B1 S1; Heating Circuit
P0135 00 [039] - Malfunction
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 233363 km
Date: 2000.00.00
Time: 16:23:58
Engine speed: 782.00 /min
Coolant temperature: 56 ?C
Intake air temperature: 21 ?C
Voltage terminal 30: 14.120 V
10065 - Mass Air Flow Sensor (G70)
P0104 00 [167] - Intermittent
MIL ON - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 233363 km
Date: 2000.00.00
Time: 16:23:53
Engine speed: 781.50 /min
Voltage terminal 30: 14.260 V
Throttle valve adapter: specified value: 100.00 %
EGR solenoid valve: actual value: 100.01 %
Charge air pressure specified value: 1043 hPa
Charge Pressure Actuator: acknowledgment: 99.98 %
Air mass: specified value: 1100.0 mg/stroke
Air mass: actual value (mg/stroke): 3276.7 mg/stroke
5523 - Engine Start Blocked by Immobilizer
P1570 00 [167] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 233363 km
Date: 2000.00.00
Time: 16:23:53
Normed load value: 28.6 %
Voltage terminal 30: 14.240 V
Immobilizer snapshot A-Sia Error Snap A: 22 A2 11
Immobilizer snapshot B-Sia Error Snap B: 1A 00 00
Readiness: 0 0 0 0 0
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BE HW: 1K0 907 379 BE
Component: ESP MK60EC1 H31 0108
Revision: 00H31001
Coding: 00000000000000000000000000000000000000
Shop #: WSC 06314 000 00000
VCID: 76E383DBC1C6F8F29E-8022
2 Faults Found:
03306 - Coding Not Valid
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 21
Mileage: 233363 km
Time Indication: 0
Freeze Frame:
Count: 3
Count: 2
Count: 12800
Count: 4161
Count: 50176
Count: 0
Count: 65024
Count: 0
01042 - Control Module; Not Coded
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 20
Time Indication: 0
Freeze Frame:
Count: 3
Count: 0
Count: 20992
Count: 195
Count: 50688
Count: 0
Count: 0
Count: 0
Address 08: Auto HVAC Labels: 1K0-820-047.lbl
Part No: 1K0 820 047 FJ
Component: Climatic PQ35 120 0606
Shop #: WSC 00000 000 00000
VCID: 71E9B0C768A8DFCA4B-8024
3 Faults Found:
00229 - Refrigerant Pressure
002 - Lower Limit Exceeded
01316 - ABS Control Module
004 - No Signal/Communication - Intermittent
01314 - Engine Control Module
Address 09: Cent. Elect. Labels: 3C0-937-049-30-H.lbl
Part No SW: 3C0 937 049 AJ HW: 3C0 937 049 AJ
Component: Bordnetz-SG H54 2202
Revision: 00H54000 Serial number: 00000008017774
Coding: A5004F0700041D025F1400001400000000187B075C00010000 0000000000
Shop #: WSC 12288 785 00200
Subsystem 1 - Part No: 1T2 955 119 A
Component: Wischer 010311 026 0512
Coding: 00038805
Shop #: WSC 12288
3 Faults Found:
00061 - Footwell Lights
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 5
Fault Frequency: 1
Reset counter: 21
Mileage: 233363 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
Freeze Frame:
ON
Voltage: 11.80 V
ON
ON
OFF
OFF
OFF
00978 - Lamp for Low Beam; Left (M29)
010 - Open or Short to Plus
Freeze Frame:
Fault Status: 01101010
Fault Priority: 1
Fault Frequency: 1
Reset counter: 21
Mileage: 233363 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
Freeze Frame:
ON
Voltage: 11.80 V
ON
ON
OFF
OFF
OFF
00979 - Lamp for Low Beam; Right (M31)
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 21
Mileage: 233363 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
Freeze Frame:
ON
Voltage: 11.80 V
ON
ON
OFF
OFF
OFF
Address 15: Airbags Labels: 6Q0-909-605-VW52.lbl
Part No SW: 6Q0 909 605 AH HW: 6Q0 909 605 AH
Component: 09 AIRBAG VW52 023 2400
Revision: 04023000 Serial number: 0037TD09YZTU
Coding: 0012345
Shop #: WSC 35110 377 00191
VCID: 7DF19CF724F0ABAADF-8028
No fault code found.
Address 16: Steering wheel Labels: 1K0-953-549-MY9.lbl
Part No SW: 1K0 953 549 CH HW: 1K0 953 549 CH
Component: J0527 056 0111
Coding: 0000534
Shop #: WSC 12345 123 12345
VCID: 7AFB97EB35DE9C92FA-802E
Subsystem 1 - Part No: 5K0 959 542 Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H05 0010
Coding: 00000131
Shop #: WSC 00000
1 Fault Found:
00888 - Wiper Switch for Intermittent Operation (E22)
014 - Defective
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No SW: 1T0 920 974 A HW: 1T0 920 974 A
Component: KOMBIINSTRUMENT VDD 1216
Revision: V0002000 Serial number: VWZ7Z0F3707084
Coding: 0016401
Shop #: WSC 00011 888 96745
VCID: 356144D75C40B3EA57-8060
1 Fault Found:
01312 - Powertrain Data Bus
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 60
Mileage: 233363 km
Time Indication: 0
Date: 2000.00.00
Time: 00:00:07
Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 N HW: 1K0 907 951
Component: J533 Gateway H43 1623
Revision: H43 Serial number: 111211F6002172
Coding: 467001
Shop #: WSC 35110 377 08192
VCID: 3B7552EFBA64659AA1-806E
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO VDD 1216
Shop #: WSC 00137 211 56823
1 Fault Found:
02241 - Engine Control Module; Immobilizer Data not Adapted
000 - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 233363 km
Time Indication: 0
Date: 2000.00.00
Time: 03:42:12
Address 40: AC Compressor
Cannot be reached
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN2.lbl
Part No: 1T0 959 701 B
Component: Tuer-SG 024 2316
Coding: 0002679
VCID: 366343DB4146B8F25E-8062
1 Fault Found:
00131 - Outside Door Handle Illumination/mirror Light Driver Side
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K0 909 144 P
Component: EPS_ZFLS Kl. 000 3305
Revision: 00H22000
VCID: 377D4EDF464C41FA45-8062
Address 46: Central Conv. Labels: 1K0-959-433-MIN.clb
Part No: 1K0 959 433 AK
Component: KSG 0401
Coding: 008A0C087F2D8405485A010010C0
Shop #: WSC 07021 210 01865
VCID: 79F988E730D8978AF3-802C
Subsystem 1 - Component: Sounder n.mounted
Subsystem 2 - Component: NGS n.mounted
Subsystem 3 - Component: IRUE n.mounted
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN2.lbl
Part No: 1T0 959 702 B
Coding: 0000614
1 Fault Found:
00132 - Outside Door Handle Illumination/mirror Light Passenger Side
Address 56: Radio
Cannot be reached
End-------------------------(Elapsed Time: 01:59)--------------------------
attempt with this
143B600D092300FD281006EB9 0220042350800
