Page 1 of 7 123456 ... LastLast
Results 1 to 15 of 96
    Ireland
    Default 2009 VW Golf 6 ABS Coding MK60EC1
    Just wondering if anyone can help me with coding for this ABS.
    ABS Part Number 1K0907379AD
    MK60EC1
    VIN: WVWZZZ1KZ9W472255
    Car is a 2.0 TDi. RHD. Ordinary specification- not gtd. It does not have TPMS.
    I have attached an autoscan from the car.
    Thanks,
    Ronan
  2. The Following User Says Thank You to sherl645 For This Useful Post:
    houdiag (15th September, 2016)
  3. #2
    V.I.P. Master of the IMMO
    lupu_sandu's Avatar
    In my immobox...
    143b400d092900fc280d02e9901e00843000
    143b200d092900fc280d04e9901e00843000
    133b200d092900fcc80d04e9901e0084b000
    133b400d092900fcc80d02e9901e0084b000
  4. The Following 4 Users Say Thank You to lupu_sandu For This Useful Post:
    bawareca (14th February, 2015), Meat-Head (19th January, 2015), RedNix (17th June, 2016), sherl645 (19th January, 2015)
  5. #3
    Ireland
    Thanks but none of those work for me. "Coding Rejected Error 31 request out of range"
    Ronan
  6. #4
    Meat-Head's Avatar
    CONFUSED
    for leeching reasons what does all that mea?
    thankssss
    Ireland
    Sorted. Thanks anyway
  8. #6
    Meat-Head's Avatar
    Well post the solution fir the next leecher
  9. #7
    svrecar's Avatar
    use this.
    it is not perfect, but works.
    Br,
    WpfApplication1.rar
  10. The Following 8 Users Say Thank You to svrecar For This Useful Post:
    BRUNOXXX (11th May, 2022), BusCan (8th February, 2021), dunnnia (30th September, 2016), jmac200t (10th July, 2016), lprot (19th June, 2022), mickye_dj (2nd November, 2018), workas (24th September, 2016), xipsilon (28th September, 2018)
  11. #8
    In this codings from lupu I see not correctly selected bits for engine type. I have big base of codings for this pump and I can make it too. This program in link is very old with some errors.
  12. #9
    Ireland
    I found coding of a similar car and changed the Vin Bits and a few other changes and it finally worked for me. Was a lot of trouble though.
  13. #10
    DK Veteran Keithuk's Avatar
    Aug 2010
    England
    Keith
    2010 Golf GTD (170)
  14. The Following User Says Thank You to Keithuk For This Useful Post:
  15. #11
    For me, making coding is 15 minutes job. I have calculated coding for Touran/Golf/Octavia from 2005-2007 years for this pumps and everything works like a charm.
  16. #12
    Dec 2012
    EU
    Quote Originally Posted by 1 6 D View Post
    for 2.0d engine typ byte 16 is (82)
    Auto Locksmith,Tuning,Dpf Removal,Dtc Removal,Immo Removal,Ecu Adaptation,Crash Data-Clear.
  17. #13
    Dec 2012
    EU
    for high spec car is not easy for low spec is not to bad
  18. #14
    I have written this incorrectly. I have calculated coding For 2004-2007 cars, where was MK60EC1 pump swapped. We know that MK60EC1 was mounted from 2009 year. This pump can be easily swapped to older PQ35 cars without fabric MK60EC1.
  19. #15
    I have a similar car and complains about ABS and SRS not coded. I calculated the coding using AVDI but don't know the procedure to input as i tried but failed. Does it need security stuff or login to work?
    Sent from iPhone 4S
