Results 1 to 10 of 10
    gpmoto2's Avatar
    Sep 2011
    Default The problem with reading motorola MC9S12XHZ384
    Hey friends!
    Motorola wants to read MC9S12XHZ384 XprogM 5.3 but does not work
    Seat Mii is a dash or VW Up
    I have a description does not work but does anyone have any idea?
    thank you!
    Oct 2013
    GB
    I think with upgrade v 5.51 xprog to read this mcu.
    Feb 2013
    UK Bristol
    gpmoto2 i know Thread is from 2015 ;-p
    Need helps with this odometer As Well
    I got Orange 5 (Clone), Xprog 5.5.1 (Clone) i can update/flash to 5.5.5 and have USB-UPA 1.3 (clone) and just without problem read Orange 5, but Orange 5 detect Secured protection, and bassicly Orange doesn`t support Secure Chips (i think), reading both memory (eeprom and flash), but eeprom every time with little diffrent content.
    In software There is option to UNSECURE but procedure of this is Erase Eeprom, Erase Flash, Boot and then UNSECURE... but i need first read all data.
    Xprog 5.5.1 with adapter 1-002-0017 with connected EXTAL (12 cm cable twisted witg GND), and external power supply doesn`t want boot and detect chip, of course tried lift up reset, BKGD and EXTAL but steal without lucky.
    USB-UPA 1.3 doesnt have to choose script MC9S12XHZ384, it is MC9S12XHZ256 and MC9S12XHZ512 but not MC9S12XHZ384
    My post helps you? Please Hit Buttons
    Feb 2013
    UK Bristol
    No one helps? Have now urgent and emergency situation. Cluster not show nothing on the screen. Just backlight... it is possible broke s9mething inside flash or eeeprom.when tried boot chip using ipa or xprog... or when.i read orange 5?.
    Any one have dump flash? Or eeprom.as well. Maybe i try unsecure using orange 5 but need correct dump. Cluster is 1ST920960L
    biya's Avatar
    Jun 2016
    the world
    desoldering reset the electronic plate
    Feb 2013
    UK Bristol
    I do this before, i desolder resistor 1k and wired was soldered streight to pin Reset... will double check maybe is under chip some circuit, but not desoldered bkgd, should helps?
    P.s have someone Script to USB-UPA 1.3. For.this chip.. om the list is 256 and 512 but not 384
    mexanico1971's Avatar
    portugal
    Quote Originally Posted by pocinas View Post
    Mate ! have read it ?
    I have here VW golf 6 MM that died and can"t read it
    Best regards
    My work is my life ART TECH GARAGE
    Sep 2012
    what tool are you using?
  9. The Following User Says Thank You to perukeyservice For This Useful Post:
    mexanico1971 (25th May, 2024)
  10. #9
    Feb 2013
    UK Bristol
    Quote Originally Posted by mexanico1971 View Post
    Best regards
    Cant remember. It was 5 years ago
    Sent from my SM-N986B using Tapatalk
  11. The Following User Says Thank You to pocinas For This Useful Post:
  12. #10
    portugal
    Quote Originally Posted by perukeyservice View Post
    I have UPASS Xprog and odis
