Any one point me if i can update webtv m3u files and how . thanks
I am having the same challenge, not sure if V8s takes m3u files and where to find the files. You can update by USB in web tv I guess.
Any help woulf be great. thanks
there is a rar file in downloads which i uploaded.
http://www.digital-kaos.co.uk/forums...o=file&id=3165
soz to b pain when i update with usb it said webtv.m3u failed any helps pls.Thanks
done that but still says the same.could it b the firmware on my box or anything els?
tims2k1888this rar file is how to edit your webtv unrar the HOW TO EDIT WEBTV and it will explain everything for you ther is 2 files in the download.
Hello.
I know how to edit and create m3u files.
I read the files provided by hfxlad.
The problem is the same.
When I try to read m3u file from dongle Open box V8s say it failed.
Anyone with any ideas? I try to goggle this problem, lots of people complaint but no one really give a solution.
when you say dongle? do you mean usb?
does the box recognise the usb when you plug it in?
try useing the back 1
and also try formating the usb aswell
and if you can try another usb.
ok good luck with it
