Hi friend, Some time ago, my tuner dpf delete. After this operation, the engine is working ok (limp mode and regeneration ok) but what i have 500km on the dashboard lights and CODE 55 dpf.
The message disappears if the ecu makings filter replacement. There is a chance to fix the file?
recode clocks for no dpf!!!!
Auto Locksmith,Tuning,Dpf Removal,Dtc Removal,Immo Removal,Ecu Adaptation,Crash Data-Clear.
catala20032004 (17th March, 2015)
i think opcom not suport astra j for this,but not easy even with dealer toll.astra h easy but astra j not so easy.
Tech2 not support AstraJ for this one You need MDI
No configuration w\wo dpf, i change dashboard with benzine and...code 55:-D Tried clear eprom but dtc in dashboard save on Nec.
I have ori opcom and i have configuration but no dpf, this is astra 4 not 3.
last hope could be dpf emulator for denso opel ecu, that are simply 4 wire to connect rear obd socket. It clear dpf dtc related everytime ign is on.
ProTuner since 1999
On Astra H and Zafira B must be changed configuration in dashboard.
In Astra J no have solution to configure dashboard to NON-DPF Because no have cars in that years of production without DPF
Only good DPFoff solution
I think your post MB275700-1011.rar is not original file.. post orig.. may be you after help..
Do not forget to THANKS !
SWIFTECH FULL
ECM Titanium FULL
KESS V3
AUTOTUNERS
B-FLASH
WINOLS
TOPDONE
AUTEL
FILE SERVISE .. web under construction
... or you need from cleaned DPF OFF solution with counter stopped.
BR
All full worked manual solutions - FAP/DPF OFF, Adblue/SCR OFF, EGR OFF, TVA OFF, SWIRL OFF, O2/Lambda OFF, DTC OFF and etc
Our database available for download 24/7 on EVC server for all legal WinOLS users
only manual solution with counter stop 100%
sos pleas idem problemAstra 2012 1.7 125cv denso caputi backup originale.rar
