sorry i forget add files, here is origo and mod
hi, i have a really interesting problem, i remove DPF on one Passat in year 2012, 3 years car work without problem, but now customer come back to me, that have problem whit car, when motor is heated up on display is showed "DPF problem - go to service", second problem is when i keep gas whit accelerator pedal motor tear, when i turn on tempomat car go smoothly
mate your file is not good. Dpf isn't stop, maybe you made dpf off by ecusafe or volta. The best removed is manual
best regards
can someone help me turn off correctly?
The solution you flashed is not good, I confirm.
Chiptuning fanatic - FILE SERVICE 24/7! Chiptuning / Dpf off / Egr off / DTC off / etc.
Bapro 4x4 dyno + SP6
Flex / X17, Autotuner, Bflash, NewGenius, FGTech, HPTuners, BitBox, PCM Flash
now i see, that file is different i write to car 3 years before, here is file i write to car, is same wrong?
yes it s bad too
Mate your second file is similar as first dpf off.
It is really miracle that car work 3 year with this decision.
can someone make me dpf off?
here you go
Pass in PM
WinOLS (VW Passat (DPF_OFF) - 389858).rar
yeager (26th January, 2015)
Or this, vcds and replacement dpf.
