Results 1 to 9 of 9
    Nov 2011
    Default psa edc16 disable dtc
    Maybe anyone could disable dtc P1446?
    p1446.rar
    portugal-ourem
    Good day. I have a solutions. NO EMAIL ADDY'S
    Nov 2011
    If you have a solution so where is a problem?
    Fantomisback's Avatar
    Aug 2012
    Quote Originally Posted by pagautas View Post
    p1446.rar
    Removed P1446 pass in PM
  5. The Following User Says Thank You to Fantomisback For This Useful Post:
    pagautas (28th January, 2015)
    Nov 2011
    thanks, will try and report this evening
    Nov 2011
    long time passed but back to this
    file not correct
    it just don't display error but still check engine and fault on display
    Mar 2013
    this is an additive fault, try disconnecting additive ecu
    if you removed dpf only by switch and additive system is faulty, you need extra work
    best is to remove FAP function altogether.
  9. The Following User Says Thank You to lucim12 For This Useful Post:
    butchh (15th April, 2015)
  10. #8
    Nov 2011
    I've removed it by switch. there is no additive ecu in the car and it's not possible to disable it using planet.
  11. #9
    Mar 2013
    you need to disable in flash file
