Results 1 to 11 of 11
    258's Avatar
    Germany
    Default MINI R50 2005 need eeprom+Flash from Dash 912dg128a 3k91d hw 30 sw 22
    I looking for eeprom and flash for MINI R50 Dash 6211-6972085 inside 912DG128A Mask 3k91d HW30 SW22.
    258's Avatar
    Germany
    nobody has this dump?
    I found this flash & eeprom same as you wanted but it's in different format.
    If I'm not mistaken you read yours with x-prog?
    The one posted here, i believe it was read with R270 or Rosfar
    You can convert it to your programmer format.
    I already check, there are good flash & eeprom
    If you need me to convert it for you, I will post later.
    http://www.digital-kaos.co.uk/forums...highlight=mini
    258's Avatar
    Germany
    hi,
    yes i use X Prog and have not R270 only 260 ,can eeprom read is same Xprog read.
    Can you please convert flash file for me, eeprom is ok.
    Can you check my flash? i post here
    here is your repaired flash I did for you.
    I do not own an X-prog but I seached &
    found flash in mini is a common problem
    damage by x-prog.
    AK400 too will damage flash while reading eeprom/
    occationally R260 also damage flash.
    I got the feeling programmers are not always to be blame.
    I suspect it's our soldering.
  6. The Following User Says Thank You to bender For This Useful Post:
    JMTec (16th April, 2021)
    258's Avatar
    Germany
    Big Thanks to you, I tried same problem needles not work, only Airbag light. Flash after written same , eeprom original from this car written.
    I have read all with x- prog and then corrected with Rosfar eeprom, then work in the Dash nothing.
    I will double check my repaired flash again later. I suspect I miss something. - checked ok
    you should use post #3 eeprom too, in case your eeprom is damaged.
    Last edited by bender; 31st January, 2015 at 02:52 AM. Reason: adding my checking.
  9. The Following 2 Users Say Thank You to bender For This Useful Post:
    258 (5th February, 2015), Yhoni (27th April, 2021)
  10. #8
    258's Avatar
    Germany
    A Question: by damage flash im mcu from dash no needles work,climate control not work, back Light from Cluster not work?
  11. #9
    yes is possible
  12. #10
    258's Avatar
    Germany
    My problem was broken flash when read with Xprog, I tried to read with lifted Reset and Xtal pin - not work again after the write verify was, and was successful. After reading was also verify and that has made Flash broken. I've turned off verify and everything is working properly.
    My eeprom was ok, not corrupt
    Flash have 8 adress-bloks (start adress 8000,18000,28000,38000,48000,58000,68000,78000), first 2 blocks corrupt (FF or 00) if read Flash and veryfi, without verify all ok!
    Now work Dash needles, Climate control work also.
    Xprog need pin Reset lift from PCB and Verify OFF by HC912DG128A ACPV 3K91D.
    Thanks to all , bender thank you for Flash.
  13. The Following 6 Users Say Thank You to 258 For This Useful Post:
    brend (22nd December, 2018), DiagExpert (16th February, 2016), elecautocr (11th June, 2019), jackeldestripador (21st July, 2015), speedservice (28th February, 2015), Yhoni (27th April, 2021)
  14. #11
    Jul 2023
    Quote Originally Posted by 258 View Post
    I have a similar problem with r270, there is no other programmer, alas (can you tell me what to do?
