Results 1 to 8 of 8
    credoline's Avatar
    Србија
    Default Focus 1.6 TDCI EGR problem
    I have try to remove EGR with AES Universal EGR Remover v2.2 but not work at all. ECU is Bosch 0 281 012 487 Bosch 7M51-12A650-UB.
    Original flash and not working file attached. Car is Ford Focus 1.6 TDCI.
    Anyone can help it wih this ?
    Thank you
    Feb 2013
    Quote Originally Posted by credoline View Post
    Thank you
    Swiftec (Ford Focus 1.6_TDCI egr_0 SW#1037380350).rarSwiftec (Ford Focus 1.6_TDCI egr_0 SW#1037380350).rar
    done friend
  3. The Following User Says Thank You to FA2ST For This Useful Post:
    credoline (30th January, 2015)
    Fantomisback's Avatar
    Aug 2012
    Thank you
    THAT PROGRAM NO WORKING GOOD
    Here is EGR OFF pas in PM
  5. The Following User Says Thank You to Fantomisback For This Useful Post:
    credoline (9th February, 2015)
  6. #4
    Sep 2013
    Belarus
    DPF EGR OFF all disconnect
    pass PM
  7. The Following User Says Thank You to vitdia For This Useful Post:
  8. #5
    credoline's Avatar
    Србија
    You did not send me a pass...
  9. #6
    credoline's Avatar
    Србија
    I try it your file and work good. EGR connector is connected to EGR and i have no DTC. If i disconnect connector, i get one DTC related to sensor A but car still work OK.
    Quote Originally Posted by Fantomisback View Post
  10. #7
    credoline's Avatar
    Србија
    I did not try your file because owner want DPF to be in function.
    Quote Originally Posted by vitdia View Post
    pass PM
  11. #8
    Aug 2012
    leave egr conected and all be fine
    best regards
  12. The Following User Says Thank You to Fantomisback For This Useful Post:
    credoline (19th February, 2015)
