Results 1 to 3 of 3
    Sep 2010
    Default help if can i read this ecu bdm
    hi to all
    please i have hammer h3 year 2003 ecu demage
    i get anther ecu from scrap but naw i need program its to car . the problem i dont have tool can do that like tach2
    naw i need ask if i can read ecu bdm to copy data from anther car to this ecu ?
    ecu in attach
    king regards
    boomeer's Avatar
    Aug 2010
    BELARUS-GRODNO
    Without tech2 it's problem! Do you try open it what is inside?
    REMOVE ALL DTC-EGR-DPF-FAP-FLAPS-CHIPTUNING-IMMO-CRASH
    CLONE ALL VAG ECU !!! REPAIR DUMP ELV,EZS COMFORT AND ECT..
    REPAIR DUMP STEERING ANGLE SENSOR !!! REPAIR DUMP BCM2 !!! KEY PROGRAMMING !!!
    Sep 2010
    thanks for replay
    i cant open becose the ic and cpu in snther said and if u need opn need remove all pins its to hard
    regards
