got this fix.
HI all anybody had a problem with I30 hyundai 2009,after ignition off immo light stays on,car not starting.after ignition ON immo light flicker a bit and stay on all time,
i check supply vol.and earth all ok.
maybe some one had a problem like this,would save me time
Auto Locksmith,Tuning,Dpf Removal,Dtc Removal,Immo Removal,Ecu Adaptation,Crash Data-Clear.
got this fix.
there is a lot on internet about this but no solution given.
its wiring problem SMART BOX communication line to ECU.
And not easy to find this immo box if you do it first time,you have take steering column down and its above the plate that steering column is fit it to,smal black box,impossible to see with steering column fit it.
obdsystems (6th February, 2015), totalkey (6th February, 2015)
i can to sloved your problem
in pm
mcgywer (18th January, 2019)
thanks gttuning.
the hyundai i just done had water ingress on BCM. A common problem on a Mrk3 Coupe
I am a FUD
DTC in ECU is P1690
Stelaras26 (28th June, 2018), totalkey (8th February, 2015)
i have hyundai i30 2011 with immo problem.
in ecu get 1690 code - no response from smartra.
Changed smartra but same error
Smartra have + 12V and GRD
immo coil lines are ok.
I only have one strange thing - on smartra communication line in shortened to GRD.
Any idea?
Thanks in advanced
Mat
Immo light lights only for 2 seconds and then goes off.
If i disconnect smartra immo light also lights for 2 seconds.
Any idea?
Problem solved:
communication cable from smartra to ecu pin 2 smartra on right pillar has short to ground.
Thanks all
