This is dpf off but but sensor must be ok, use vcds and replace dpf.
JIMMYQ (5th February, 2015)
thanks and much appreciated I have this file too which has a lot more data changed which one is better and 100% ?
Hello.here is a similar problem with passat Have the edc17cp14 0281015029.Here is my work.Can somebody check if i found the right switch for dpf?
Thanks for help.
illestibor,
No, your solution will be not work, did u even know what was shut down ?
You removed CEngDsT_idxTempThres_C this is index select for intake temperature
All brand FileService - Custom - remapping company
POWER>DPF>EGR>KL>SCR>TVA>DTC's>Lambda>NOx>CustomSp ecialization -
| Diesel | Bosch/Siemens SID/Denso/Delphi/Visteon/Phoenix
I think that i'm confused.A hepl will be thanked.Where can i found the switch?
Can somebody help me with the line adress where to find to correct switch.Thanks for help.
1EFED2 and 1EFED4 i think.
VAG
I help you, but needed wait for couple minutes free time.
There is only one adress
here you are, pro solution.
No dtc touching, DPF function works, but DPF by own automaticaly not !
PW PM
illestibor (12th October, 2015)
