Results 1 to 2 of 2
    May 2008
    Default Pixeling with the Kryptview
    Hi All, after a week of searching the web I managed to download and install the latest firmware for my KryptView. On the 53rd attempt I managed to get the location names up so that the box would scan more the the default TPs. My problem now is how to stop the pixeling. Most of the TPs are ok now that I have wired in an attenuator but there are still 4 TPs that wont settle down.
    Does anyone have any suggestions.
    Jun 2008
    With the Krypt view you can put the cable feed into the bottom cable (output) socket and it will work as an atenuator and may well cure you problem ! give it a go i did and it worked fine for me.
