Results 1 to 3 of 3
    Sarkan's Avatar
    Default How to reanimate killed Autocom
    I have AutoCom that worked well with 2012.3 software.Unprovoked due to sheer stupidity I installed 2014.r2 version to another machine.I connect Autocom and program ask updete firmware.OK I press the update button and update goes for some time and interrupts.Red LEDs glow steadily.I tried to conect on the machine with installed 2012.3 version
    but nothing happens.Red LEDs glow steadily.How to program the flash and which programmer i use.
    All you need here:http://yadi.sk/d/RocSE13ycmJxA
  3. The Following 5 Users Say Thank You to stas12 For This Useful Post:
    abdonete (17th October, 2015), apv (25th February, 2015), mohamedkey (6th June, 2015), Sarkan (17th February, 2015), stefaudio (14th February, 2015)
    Sarkan's Avatar
    Thanks for the info but I've already done according to these instructions.
    http://www.digital-kaos.co.uk/forums...VCI-not-FOUND)
    I did not even have to connect the reset button.If connect the reset did not want to erase flash.In the folder where it is installed Autocom is the firmware folder.There is OBD_VCI + hex file size 701KB.I put him in a file for writing to the programator.Next, and program is started.At the end programmator show that verification succeeded.Later, when I hooked it up to a laptop and car asked the update as the first time it was installed.I did it and Autocom is revived.
