Results 1 to 4 of 4
    Lithuania
    Default Passat 2008 simos ppd1.2 dpf off
    Hi, plase check dpf off is it correct.....
    With this dump dont have errors , but DPF light is still on. Customer com from another garage.
    Solved..... made extra 5 km and lamp off
    Member ecusoftbelgium's Avatar
    Nov 2014
    Belgium
    No DTC in ecu?
    Also do you have a diagnostic tool who can reset dpf and reset pressure sensor?
    Sep 2013
    Belarus
    after reprog need reset dpf or 20-30km drive
  4. The Following User Says Thank You to vitdia For This Useful Post:
    darius89 (12th February, 2015)
    Lithuania
    Pressure sensor reseted. but no option to reset dpf.
    But 5 km solved ......
    Thanks VITDIA for info
