Yes no work... after arrive home i make for you...
pass PM.. Im arrive home..
PPD.ZIP
PPD.ZIP
Do not forget to THANKS !
SWIFTECH FULL
ECM Titanium FULL
KESS V3
AUTOTUNERS
B-FLASH
WINOLS
TOPDONE
AUTEL
FILE SERVISE .. web under construction
tipoune2002 (15th February, 2015)
it's ok but a little smoke (egr?)
Yes posible.. egr not close.. little smoke normally
SWIFTECH FULL
ECM Titanium FULL
KESS V3
AUTOTUNERS
B-FLASH
WINOLS
TOPDONE
AUTEL
possible close egr electrique?
egr closed but still smokes
does not function correctly
at each start-up, the car white smoke please help me
help me please
for white smoke you must check the injectors,not are from egr
Mike
or dpf off is not made properly and car still regenerate
Interested,, im test to many cars this solution...
SWIFTECH FULL
ECM Titanium FULL
KESS V3
AUTOTUNERS
B-FLASH
WINOLS
TOPDONE
AUTEL
the car did not
smoke before dpf
If you cut DPF filter and after start smoke it is normal you have problem with INJECTORS.
I do not understand the relationship with dpf / injectors, smoked just at startup, no driving
