Page 47 of 114 FirstFirst ... 3742434445464748495051525797 ... LastLast
Results 691 to 705 of 1700
  1. #691
    Ukraine
    Volvo S60 2012, dash, DDM and PDM working good.
  2. The Following User Says Thank You to andrej_z For This Useful Post:
    maybach_ (21st November, 2018)
  3. #692
    wadim21's Avatar
    Sep 2011
    Renault Scenic3 ecu SID 305 mileage by obd.not working. Read mileage ok, but could not change.change Only last regeneration mileage
  4. #693
    wadim21's Avatar
    Sep 2011
    Passat B8 2015 VDO not working.OBD STAR 3min job
  5. #694
    Dec 2017
    Hello, is possible to do bmw x6 2012 cas thru obd or must remove and do the cas manuel with other programmer ?
  6. #695
    Nicolas9's Avatar
    Feb 2017
    Aruba
    Quote Originally Posted by shotaaa View Post
    is possible. but not all software versions.
    let us know if yours worked
  7. The Following User Says Thank You to Nicolas9 For This Useful Post:
    shotaaa (27th August, 2018)
  8. #696
    Feb 2015
    Lincolnshire
    any body done dash swop on 2011-2016 caddy? is it full obd or bench job?
    Stop getting worried about what could go wrong, and start getting excited about would could go right!
    hmmmmmmm........eeprom
    Digi v4.94, Xtool, R260, R270, Smok, VagProg DataSmart 3+ Smelecom, Autel Maxisys ms908, SpeedFilters
  9. #697
    Dec 2017
    Hello did somebody tried fiat talento 2017 ?
  10. #698
    Aug 2018
    Francja
    szukam dowland ​magic dash can.rar
  11. #699
    wadim21's Avatar
    Sep 2011
    Espace 5 abs via obd—-ok
  12. The Following User Says Thank You to wadim21 For This Useful Post:
    maybach_ (5th January, 2019)
  13. #700
    Dec 2017
    May I know how good it’s on PSA cars
    As all French cars have BSI
    Tanx
  14. #701
    Nicolas9's Avatar
    Feb 2017
    Aruba
    Quote Originally Posted by Happy786786 View Post
    Tanx
    not all french cars.
    it works fine. mostly until 2016. and valeo also 2016-
    smok is better
  15. The Following User Says Thank You to Nicolas9 For This Useful Post:
    Happy786786 (31st August, 2018)
  16. #702
    Nicolas9's Avatar
    Feb 2017
    Aruba
    Quote Originally Posted by wadim21 View Post
    which option did you select in menu?
    and how long did it take?
    thnx
  17. #703
    wadim21's Avatar
    Sep 2011
    Megan 4, Scenic 4
  18. The Following User Says Thank You to wadim21 For This Useful Post:
    Nicolas9 (29th August, 2018)
  19. #704
    Dec 2017
    Somebody tried volvo v50 2009 OBD ? I get comunicetion error.
    And also autodetect dash can not found wich model..
  20. #705
    Dec 2017
    Quote Originally Posted by Nicolas9 View Post
    smok is better
    Tanx
