tooday tried ecu sid 305 .read correct and write.with diagnostic tools show km real .....money lost on the update........ and suport 00000
blackpirate (16th February, 2019)
Stop getting worried about what could go wrong, and start getting excited about would could go right!
hmmmmmmm........eeprom
Digi v4.94, Xtool, R260, R270, Smok, VagProg DataSmart 3+ Smelecom, Autel Maxisys ms908, SpeedFilters
I did milleage correction to VW Polo 2012 johnson control cluster. Everythinh went good. After a hour old mileage is back.
any suggestions?
teerak2uk (13th February, 2019)
I had the same issue with fabia JC. It was not possible with x-tool at that time.
Which software version do you use ?
Did a lot of these with SMOK - no problem.
jc work , kermol fixed!first prepare obd ... after wrete km!
sid 305 not all version work! smok, mdflasher, same .
Range rover 2016. Not working.
Seat Leon 2014. Recognize but not change.
Scenic 2 via obd2. Perfectly.
Espace 5 dashboard obd-ok. ABS obd-ok
