polo sedan 2016 not ok
Is there a solution !
thanks digital-kaos
gm trailblazer ss 2003 ? done obd ok
audi a6 2002 done obd ok
2010 dodge ram 4500, done with 2500 menu done obd ok
anyone able to do 2009 audi tt ??
follow us to watch great videos everyweek
<a data-cke-saved-href="https://youtu.be/y0lDbO_YPG0" href="https://youtu.be/y0lDbO_YPG0">
hi
C5 2011 bsi JC obd ok
dash eeprom c76x16 ok
regards
Please dear members push the button thanks and reputation button(stars)
do you need help? fill it in !!!
Model:
Motor capacity:
Diesel/Gasoline:
Production year:
ECU type and number:
Memories :
https://www.digital-kaos.co.uk/forum...63#post1660863
HeXeN (19th July, 2019)
Hello, I am a user of X-Tool but I have not updated since 2017, a companion updated until 2018 and in the option Renault / Renaut 2015 .. appeared several options that were not until 2017, in this version only read / wrote by checking the box but now there are several options, both in board and in ABS, we have not been able to make them work correctly. They could help me understand how to select the right options to successfully modify the mileage, even let it be changed again in the future. I thank you in advance for your help.
Thanks for answering, the problem is that depending on how you use it you can block ABS and it does not allow you to modify the kilometers, that is a serious problem for everyone.
We believe that an interpretation could be:
DASH:
"Km 2013 .. only DASH" and "Km 2017 .. only DASH" to read board Km for the first time. But if the ABS is blocked (once the Mileage was modified with which the ABS is blocked, in case of X-Tool old versions) we should use the option "ABS is blocked in Flash".
ABS:
"Only Write" .... ?? What will it do?
"Unlock DASH" ?? When can the board be locked?
"Block ABS" .... ?? It will be useful for when the mileage was modified before and ABS lock when rewriting ??
Many doubts, who think or contribute from their experience of use? We thank you in advance for your help. Best regards!
I get "interface error" when i try to open xtool.
Any idea ?
It does not present any inconvenience in its connection.
Hi guys.
Anyone knows if Elantra nec 2004 works by dash plug?
(Maybe any tips if not work directly?)
Thnx
seat cordoba 2007 not read km and pin, identy versión but not recognize.
